Question about Heath Zenith 270 Degree Replacement Motion Sensor - White, SL-5716-WH
With wall switch turned on, motion detector keeps coming on and off every 2-3 seconds. i have unit set for 5 min. can yoy please send me a coupon for a discount on a replacement. i have 4 of your units on my property and this one is driving me crazy. i spoke to one of your customer service reps and he told me about a paper test to put a piece of electricial tape over black window but there is no black window on this unit. i do not have model # but i remember the cost was around $20 at home depot .please help! my name is bill sargent adress is 620 south pine creek rd,fairfield ct 06824 thank you
3 Suggested Answers
  • 5603 Answers
SOURCE: Hi I have a dusk to dawn motion light. It is the
Some of these fixtures have a function built in that turns the light on solid if the power is cycled rapidly several times. If you have had power glitches and this unit has that function, it might be locked on.
Pull the circuit breaker for the light for a couple minutes then try re-powering it to reset the function.
Posted on Jun 08, 2010
  • 8457 Answers
SOURCE: I have a Journeyman outdoor
U live in cold place drop down to the 30 some times?The Sensor,it not dectecting,because of the mucury inside the device not as good as before.Take the divice out put it near a portable heater 24 to 48 hours.The device should work again than.
Posted on Dec 31, 2010
I want my motion securtiy light to acturally stay on all night. more after animals than people, can this be done?
Usually with mains power motion lights if you switch them on and off two or three times and then back to on, the light will stay on all the time. To put it back to motion, switch off, wait a minute and then switch to on.
This is borne out by this article
Search Results Most motion detectors have a built-in override:
  1. Normally the switch is kept on all the time. ...
  2. If you turn the switch off and on within a second or so, the light will stay on, and this overrides motion detection.
  3. To go back to normal operation, turn the switch off and wait ~10 seconds, then turn back on.
More items...
lighting - How can I override a motion detector light? - Home ...
https://diy.stackexchange.com/questions/.../how-can-i-override-a-motion-detector-light
make motion security light stay on Google Search
Sep 04, 2017 | Home Security
How to reset/fix an indoor motion detector?
Depends on the model of the detector, but wireless motions are not supposed to light up; if they light up they have been put into test mode, either by opening the tamper switch, removing and reinserting the battery, or by positioning an internal jumper to the test position. If the motion is a 5890(PI), remove the batteries and short the empty battery sockets for about 30 seconds to reset the low battery circuit, then reinsert the batteries and close the cover, making sure the tamper switch is properly closed. Other motions don't need this reset procedure, but do need all tamper switches closed. Ensure no one is moving near the motion and reset the keypad by entering your code plus Off (just like coming home). If everything is right and all other devices closed the ready light should come on.
May 01, 2014 | Honeywell Ademco Apx32en Alarm System...
I want to replace my existing single bulb porch light with a 2 bulb motion activated light. It would be operated with the existing switch. Is this ok to do?
Yes. Must keep switch turned ON.
Outdoor lights will only come on when motion is detected, otherwise light bulb does not come on. So the indoor wall switch does not work as override since the motion sensor takes over as the sole switch.
Copy following link for wiring illustrations:
http://waterheatertimer.org/How-to-wire-occupancy-switch.html#motion
Other solutions include adding separate motion sensor light nearby and keep porch light so you can turn on-off when desired.
Another option is to add photocell to outdoor light so it turns on automatically at dusk.
Another option is to use outdoor yard timer with dawn-dusk capability:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Another option is to replace indoor wall switch with with dawn-dusk timer, that can also be used as ordinary on-off switch so you can turn porch light on-off when desired. Timer such as Intermatic ST01C offers simple 2-wire connection.:
http://waterheatertimer.org/ST01C-program.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 18, 2013 | Electrical Supplies
I have a fahrenheat wall mounted heater, 120 v model,(can't find a model number on the unit) with a dial temp control. No matter which number setting it is on, the unit cycles off after about 50 seconds....
UNIT SOUNDS LIKE ITS SHUTTING DOWN ON A LIMIT SWITCH IN HEATER. THEY LOOK LIKE ROUND BUTTONS OF DIFFERENT SIZES. THE HAVE 2 WIRES GOING TO THEM AND THEY ARE A NORMALLY CLOSED. THERE IS A FAN DISK NORMALLY OPEN TO UNTILL IT GETS HOT AND CLOSES TO TURN ON FAN.  IF THE FAN SWITCH TAKES TO LONG TO CLOSE THEN LIMIT OPENS TO PROTECT FROM OVER-HEATING
Apr 23, 2010 | Fahrenheat (FFH1614) Wall Mounted Panel...
Wiring diagram 3 way motion detector switch I want the motion detector to be in the hot line box, and I want a regular 3 way to turn the light on from the load box. So far I can only get the motion...
Sorry, but you need one extra wire between the switches to wire "the opposite configuration" that you want :-(
That means going into the attic and pulling another cable :-( I can walk you through it if you are willing to do all that work.
The only other solution would be to purchase the commercial version of that motion switch, which would also require a sensor at _each_ switch location :-(
Jan 02, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
Put light in test mode, it works great. Put in 2 min or 5 min setting and it won't come on at all. What's the deal?
Could be similar to a problem I had recently where the daylight sensor was being triggered by the light itself. Try re-pointing either sensor or light to keep the sensor in the dark when the lights are on...
Oct 26, 2009 | Desa International 240 Deg. White Twin 150...
Motion Light doesn't work on switch
Try turning the switch on and off and back on again this usually will bypass the motion detector. when you are finished you can turn the switch off for a few seconds and back on and it will resume its normal function
tom
Dec 11, 2008 | Electrical Supplies
Heath Zenith 270 Degree Replacement Motion Sensor - White, SL-5716-WH Logo
62 people viewed this question
Top Heath Zenith Home Security Experts
Steve Allison
Steve Allison
Mike
Are you a Heath Zenith Home Security Expert? Answer questions, earn points and help others
