Question about Honeywell Heating & Cooling
Our Honewell system says -AC on it. is there a way to reset the system?
    Novelist:
    Champion:
  • 230 Answers
I am not sure what kind of unit this is, but AC can mean that it has lost power from the control board. Make sure the breakers and disconnect switches are all on. If they are on, then turn the power off for 10 seconds or so and turn it back on. This will reset many systems. Last of all check your batteries (if your controller uses them).
Posted on Jun 17, 2008
Honewell r666od
is it on the left or the right ?
Mar 04, 2014 | Honeywell Programmable Thermostat Heater
HONEYWELL RTH4300B
type in search bar.".download instruction manuals honewell 4300b (thermostats)"without the quote marks, you should find what you need there
Dec 31, 2011 | Honeywell Programmable Thermostat Heater
I replaced the thermostat with a new Honewell RTH 2510B model. Before I replace the thermostat, the AC repairman added the booster to the compression since he said that was the problem why it does'nt...
Check at the furnace there is a 3 amp fuse on the circuit board you might have blown it when you installed the t-stat without shutting power off to the furnace. Also make sure RH and RC are jumpered together Y= cool G=fan W= heat R=power. let me know ok
Jul 25, 2011 | Honeywell Heating & Cooling
Renting a house and there is a green flashing light on honewell furnace. Thermostat set at 70 but the temp is 54. Should I press the reset button or just call and bother the owners. Used to living in a...
Clean the flame sensor at the furance burner compartment. This is found left hand end farthest burner tube from ignitor, Make sure your filter is clean. Turn powwer off at furance and then turn back on to reset.
Jan 26, 2011 | Heating & Cooling
My honewell th8320 is reading error 126 or 626
Look in the manual that came with the thermostat it will give you the problem for each code.
Nov 11, 2009 | Honeywell Electronic Programmable...
I just purchased a honewell RTH 221 thermostat. I
Typically the four thermostat wires are:
R = power (or common)
G= FAN
W = Heat
Y = Cool
Assuming that you have a normal electric or gas furnace and air conditioning, if the heat really is coming on, then just switch the position of the the Yellow and White wires.
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
Hi i am working as an electrical installer and would like to know where i can access all the electrical drawings for all the different heating systems Honeywell
http://www51.honeywell.com/aero/Products-Services/Avionics-Electronics/Egpws-Home3/InstallationInformation3/digs-draw-sw.html?c=21
try this.. all honewell drawings.. in it
Nov 13, 2007 | Honeywell HFS641P Stand (Pedestal) Fan
Heating & Cooling Logo
69 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
