Question about Pride Mobility Products Go Go Ultra X 4 Wheel
Hi we have been passed on a go go ultra 4 wheel .it has been left unused for sometime and we cnnot get it to work.the batteries are not charging and the charge light on the chargerdoes not light up.can you help we live in taunton somerset.
    Novelist:
    Champion:
  • 232 Answers
It sounds like the batteries have gone bad and need to be replaced.
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours one day a week) of the gel will solidify. What is probably happening is charger light will either stay green, go to green after a very short time, or the charger will be connected for hours or days and the light never changes indicating a full charge. When you turn on the power chair, nothing happens. The charger may indicate the batteries are full, but instead of being full of power, they are full of crud as the gel inside them has oxidized. Since you are the second owner of the scooter, you will need to replace the batteries on your own. Check the owenr's manual for the correct type or contact Pride Mobility at 800-800-8586. Good luck!
Posted on Nov 09, 2010
Gogo ultra x runs for a few minutes on fresh charged batteries then a squealing noise starts and the brakes appear to create drag.
I would recommend to call electricians certified in your state and replace the entire circuit box new it is for safety and fire hazards
Oct 09, 2016 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Why does my Pride Go-Go Ultra X 4-Wheel not break quickly?
You may need to charge the batteries fully. You may be exceeding the hill slope recommended or exceeding the weight capacity. These are light duty scooters with light duty brakes. Slow down and enjoy the ride keeping this in mind. You may want to have the throttle potentiometer checked out. It needs to go to neutral for the brake to engage. These scooters have a relatively long brake sense engagement through the controller electronics.
Oct 06, 2012 | Pride Go-Go Ultra X 4-Wheel
It won't turn on at all. It won't even charge. It's only 4 months old. Wasn't dropped or exposed to water or elements. Was working fine yesterday morning, then about 4:30, it was dead. ...
How long did you let it charge, when the device is completely drained of power it may not turn on at first when you connect it. Let it charge for a little while and come back to see if it fixes it. Failing that, your probably going to have to contact apple for warranty help.
Jun 15, 2011 | Apple iPod touch
Hi I have a Flip Ultra Video. When it says I still have 1 hour 23 mins of recording time the camera shuts down. Battery?? I plug it in to charge and after that it says I have over an hour left of...
1) Put your Flip Ultra back into the pakaging box
2) Keep it safely inside your fridge (make sure the fridge isnt on or the best is an old fridge model)
3) Scratch your head and scratch your nuts in the same time for thirty second
4) Turn on your Flip camera, press the red button for setting, and change it to indonesian language. If no indonesian language in the setting, shake it 3 times. It surely has.
5) Jumping around on your parent bed.
6) Sing Britney Spears song and film it yourself.
7) Press stop button
8) Post it on youtube.
I hope this will fix ya problem. Have a nice day :)
Sep 16, 2010 | Pure Digital Flip Video Ultra Camcorder
Just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
May 21, 2010 | Pride Mobility Products GoGo Ultra X...
Battery charging
If you use it for an hour or so than I would charge it, at least 8 hours. Always charge it at least 8 hours. To find out if the batteries are bad have them load tested.
Dec 12, 2009 | Pride Mobility Products Go-Go Elite...
My gogo-ultra will not run. it has been stored
hi,
Check the connections between the battery and motor, if the rear come apart check there connections there,
If the connection with the batteries string loaded, rough them up slighty with a wire brush but be gentle and is there freewheel lever right in position for drive.
Regards
GeWiz.
Oct 24, 2009 | Pride Mobility Products Go Go Ultra X 4...
Battery will not charge, need a wiring schematic
Are you sure its not the charger ?
The connections are easy to follow, located the motor controller , normally a black box, now you 'll have have B+ B- make sure they are a good connection, make sure the charger connector is not faulty,
the batteries are then suspect, so can you try other batteries ?
Regards
GeWiz.
Oct 08, 2009 | Ultra Products Pride Go-Go Ultra 4 Wheel...
4 wheel drive doesn't work
sounds like the shift motor on the transfer case is going bad.
Aug 29, 2009 | 2004 Chevrolet S-10
Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
Jun 03, 2009 | Pride Value Line Revo Scooter 3 Wheel
Pride Mobility Products Go Go Ultra X 4 Wheel Logo
133 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
