Question about SIM2 Domino D80E DLP Multimedia Video Projector Projector
Sims2 Multimedia D80E problems, It stopped working and currently wont start up. When I press the start button I can hear it start up but then it stops and then starts again. before it started to do that, it would freeze while I was watching a movie and stop at one frame and make it black in white, and the projector wouldn't respond to anything and I would have to restart it but after 5 minutes of watching it would do it again.
How do I remove (uninstall) the sims 2, sims seasons and sims teen style stuff from my computer?
Hi akach564,
I saw your post wanting to uninstall The Sims 2 and the other Expansions that you have for it, since you did not mention what version of Windows you have I will be giving several way to remove The Sims2 and it's Expansions.
Win XP:
  • Click on Start, then click on Control Panel, in Control Panel look for Add Remove Programs.
  • In Add or Remove Programs it will be Alphabetically arranged look for The Sims or Sims2 and you should see the other Expansions underneath it , on the right side of The Sims2 and its Expansions you will see a button that will say change / remove.
  • Click on Change/Remove this will prompt you if you are sure you want to uninstall this program.
  • Just click on YES since we are uninstalling the program The Sims2.
  • Do the same for the Expansions of The Sims2 to uninstall them.
If the Sims2 and its Expansions are not located anywhere in the Add or Remove Programs then you will need to manually uninstall them one by one from the location where the folders of each is located C: or which ever location / folder you installed them.
In each folder of the Sims2 / Expansions you will need to click open each folder and look for the uninstall icon and double click on it to uninstall The Sims2 to the same for the Expansions of The Sims2 for uninstalaltion.
Win Vista / Win7:
  • Click on Start, then click on Control Panel, in Control Panel look for Programs it will say uninstall programs under it click on uninstall programs this will open Programs and Features.
  • In Programs and Features it will be Alphabetically arranged look for The Sims or Sims2 and you should see the other Expansions underneath it , on the right side of The Sims2 and its Expansions you will see a button that will say change / remove.
  • Click on YES to Uninstall the Sims2 and do the same for the Sims2 Expansions program/game.
I hope that this will be of help Uninstalling The Sims2 and it's Expansions game from your computer.
Have a nice day,
mvincentc
Apr 19, 2011 | Computers & Internet
My Panasonic PT-LB20NTU Multimedia Projector i locked my controls on the menu button and now it wont poer on and none of the buttons work
Use the remote control and press the MENU button and select the OPTION with the UP and DOWN arrow buttons. Press ENTER button and then press UP and DOWN arrow button to select CONTROL PANEL use LEFT and RIGHT arrow button to VALID the control panel buttons
If you have a loss of the remote control while the control panel is invalidated.
Press and hold the MENU button for 2 seconds with pressing the ENTER button to enter the MENU and VALID the control panel.
Nov 19, 2010 | Panasonic PT-LB20NTU Multimedia Projector
My playstation 3 wont start up, I press the power on button and it goes to start but then switches off
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Aug 25, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont read disks, it spools up then stops.
you can try the steps below. Its from PlayStation Forum:
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
If after trying the above options and it still does not solve the problem, then maybe the lens is weak and that's why it cannot read any disc.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck.
Jul 16, 2010 | Sony Playstation 3 (PS3) Console
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
jahting
Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
My whirlpool gold dishwasher GU180 wont start
I had the same problem with the exact same model - put your washer on the lowest wash setting - press and hold the start button for about 3 seconds. THe washer will run for about 5 seconds and then turn off (do not have the heated dry setting on when you do this).
Turn it off (turn the dial), and then try to re-wash.
Dec 25, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
My computer is not detecting microphone when making internet phone calls.
Troubleshooting - Can't get voice chat to work.
Here are a few things you should know and check for to get the voice chat to work. · Firewalls - the voice chat feature may not work well behind company firewalls. Even though you can get other features of Yahoo! Messenger to work, the voice chat feature uses separate technology and may not work as well.
· Check connection - When you enter into a voice chat with friends, each participant should take turns trying to press and hold down the Press to Talk button. Everyone else should see their name turn red when they do that. If you see their names turn red, but don't hear anything, it may be a microphone / speaker problem, or it may be that we have more bugs that we need to fix. If you don't see their name turn red, you are probably having connection problems and that's why it's not working.
· Get the latest version - Please make sure that everyone who is using the voice chat feature has the latest version.
· Check mic and speakers - Check that your microphone works and that your speakers are turned on. Here's how:
* make sure the mic is plugged in correctly.
* adjust the mic properties.
- go to the control panel (start button -- settings -- control panel)
- click on the multimedia icon
- you should see a tab for audio
- make sure that the recording volume is set high.
* you can test your mic. by doing the following.
- Click the Windows Start button, then go to Programs, then Accessories, then Multimedia, then click on Sound Recorder
- A new window called Sound Recorder will pop up. Click on the record button (a red circle), then say a few words, then click the stop button (black square).
- Click the play button (black triangle).
If you can hear yourself fine, then your microphone is okay. If you can't hear your voice using Sound Recorder, the voice chat should not work either.
Jan 12, 2008 | Toshiba Satellite A105-S4334 Notebook
SIM2 Domino D80E DLP Multimedia Video Projector Projector Logo
70 people viewed this question
Top SIM2 Office Equipment & Supplies Experts
jasbo
jasbo
Jerry Umali
Are you a SIM2 Office Equipment and Supply Expert? Answer questions, earn points and help others
