I have a linksys router, and a linksys wireless and I can't get the computer that is on the wireless to access the internet. it is telling me my IP address needs renewed. I contacted cox who is my internet provider and because I don't have wireless with them, they said it was a linksys problem. HELP
  • 58 Answers
Make sure wireless functionality is turned on the router and DCHP is enabled.
Posted on Jun 17, 2008
I have a smartbook and i need to know who give out an ip address, is it linksys or the cable company?
The wireless router issues an IP address to your all your computers.
The ISP issues an IP address to your cable modem which is connected to your wireless router and the wireless router re-issues a local IP addresses to all the computers on your local network so all your computers on your network can access the Internet and to each other cpmputer.
May 25, 2012 | Linksys WRT54G/WUSB54G Router...
Need help setting up the Sudenlink Modem to Linksys Router
Connect lan cable from modem to linksys router's WAN port.
Then configure linksys router with below method.
Yes you need wireless router to use wifi in ipod touch or on laptop.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method.
Then click on WAN settings set as your internet service provider settings like static ip address.If service provider give you user and password for connect internet then set router in pppoe mode.
Enable DHCP.
Then click on wireless and enable it.
. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 18, 2011 | Linksys WRT160N Wireless Router
My niece gave me a Linksys WRT54G wireless broadband router. But she couldn't find the installer. How do I install it to my computer?
1)Connect lan cable on any of the port in router and connect your pc? And check whether your pc is getting automatic ip and check what is the gateway defined there??And just put that ip(if default it will be 192.168.1.1) in your internet explorer and access your router.
2) If even connecting your pc its not getting any ip then reset you wireless router and login using internet explore 192.168.1.1 ip?
Sep 22, 2010 | Linksys Wireless-G WRT54G Router
I need to complet my router setup
Have you secured your Linksys from unauthorized access?
The encryption code protects your wireless router from unauthorized access. The wireless card in your computer/laptop needs to be configured with the router's encryption settings before the computer/laptop can access the router.
For details on configuring the wireless router and the wireless card, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 06, 2010 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Changing IP address on computer with router linksy802.11b
access your router with ip.
open internet explorer if your defualt router ip is :192.168.0.1 type this http://192.168.0.1 in addres bar in IE. then neter username admin and password aslo admin
if not accepr blnk user name and passowrd is admin.
then go to ssytem then set ip and follow the procedure.
Oct 06, 2008 | Linksys BEFW11S4 802.11b Wireless...
I can't reach my ip to change my lan config
yeahlife,
The default IP Address for Linksys routers is 192.168.1.1. You may want to try accessing your router's configuration by typing this IP Address in your browser.
If you have any additional troubles, please let me know.
Regards,
moriarti5
Jun 02, 2008 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
Installing a Linksys Access Point to a Verizon Actiontek wireless router.
The IP Address of WAP54G is 192.168.1.245
Connect a computer to the Access point.
Assign a static IP Address to the computer, like : 192.168.1.10 , the subnet mask should be 255.255.255.0
Open the setup page of the Access point, by typing 192.168.1.245 in Internet Explorer / Firefox. Configure the wireless settings, Change the IP Address to the range that of the Actiontek router.
Save settings. To know about wireless security, click here.
To check the latest update on Linksys products, click here.
Hope that helps :)
Mar 28, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
