TV power button
Power on does not work with remote. I changed batteries. Now power on does not work when pressing power button on TV. Does the power button ever go bad?
  • Anonymous Jul 12, 2008
    my remote that came with the Emerson TV will not work. I have ordered a new one and that doesn't work either. Can it be something with the TV? If so what is the solution?
I was told that it could be the power board.
Posted on Jun 18, 2008
Volume and mute buttons are not working
Do you have fresh batteries in the remote? You did not provide your TV brand so I can't provide you the codes for your specific TV. Below I have provided instructions on how to perform a power scan. If this doesn't work, you may need a new remote.
  • Remote: Basic Remote (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Press and release the redTV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the # button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 17, 2011 | DISH Network IR Remote Control
The tv doesn't react when pressing the power button. What can I do to fix this?
Things You'll Need:
  • Batteries
    • 1 Press the "TV" button and then press the "Power" button on the remote. If the TV turns on, your remote was just switched off of TV mode.
    • 2 Reprogram your remote to your TV. Universal remote controls can be accidentally unprogrammed by sitting on the wrong combination of buttons or having the batteries disconnect from the inner connections.
    • 3 Unplug the TV from the electrical outlet for a few minutes and plug it back in. This will reset the TV in case a power surge caused the TV to become "confused."
    • 4 Replace the batteries with new ones. Do not use old batteries from a different device in your house because if the batteries do not work, you won't be able to determine anything because those batteries may not have enough juice to power the remote. Keep in mind that different devices have different needs, so the batteries may have had enough power for something else to work but not enough for your remote.
    • 5 Check the batteries to see if they are inserted in the right direction. It's possible that someone dropped the remote, the batteries fell out and then were inserted incorrectly.
    • 6 Press the "Power" button on the TV set to determine that the TV is not dead. A dead TV will not turn on from a remote.
    • 7 Program the remote to another TV. If the second TV works from the remote, the problem is with your TV's remote signal receiver
Jan 17, 2011 | Sony Rm-yd035 Remote Control
Remote control work very slowly and sometime do not work
Please follow the troubleshooting steps:
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the buttons on the remote control are jammed.
  4. Install fresh batteries into the remote control.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV.
  6. On the remote control, press the TV FUNCTION button.
  7. Press the POWER button and other buttons to test the operation.
  8. Try using the remote control at varying distances from the TV.
  9. Power reset the TV by follow the steps:
  • Unplug the television power cord from the electrical outlet.
  • Let the television remain without power for 60 seconds.
  • Plug the power cord back into the electrical outlet.
Jan 09, 2011 | Philips 32PF9964 32 in. Television
My 1.5 IR Dish remote has all of a sudden stopped working with our Sanyo tv. I've changed the batteries. When I push the power button it will only light up the VCR button if anything at all. Our other...
sandyannsamp
If the VCR button lights up when you press the Power button, you are not in the correct mode to operate the TV. If the remote is programmed correctly, when you are in SAT mode, you can press the large RED button to turn your receiver off/on. The RED TV button will turn your TV off/on. I have provided links to program your remote to your TV again. I have also provided codes for your Sanyo TV.
Instructions to program your remote to your TV (begin with step 6):
http://www.dishnetwork.com/SupportSection/remote-setup
Here are the TV codes: 590, 683, 589, 542, 652
I hope this helps.
Ray Calo
DISH Network
Nov 18, 2010 | DISH Network IR Remote Control
Not able to turn tv on with remote
First try changing the batteries.
Next make sure when you press function on the remote control the red light on the remote displays under tv
Next try a remote reset:
You have to unplug the television after turning it off. Take the batteries out of the remote control. Point the remote toward the remote sensor (bottom right hand corner of the television set). Press the power button on the remote control and hold it down for 30 full seconds. Next press and release every button on the remote control. Next plug the tv back in and power it on from the power button on the television itself. Replace the batteries. Adjust the volume using the remote control. If that works the problem is solved. If it doesn't work you may need a software update, a new remote control, or repair to the sensor on your television.
To see if your remote control is working look at it through the viewscreen of a digital camera. The digital camera must be turned on and ready to take a picture. Next press a channel button on the remote control. Do you see a bluish white light? If so the remote control is ok.
Aug 24, 2010 | Sharp AQUOS LC-32D43U 32 in. LCD...
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Aug 03, 2008 | Televison & Video
Viewsonic remote RC00070P
Okay here's the fix.
Remove batteries. Re-install them wrong side in! Don't panic.
Reverse the direction of both the battery cells and install. Press "Power" button a couple of times and a few other buttons a few times. Then remove batteries and re-install the right side in.
Voila.
Jun 10, 2008 | Televison & Video
Echostar IR remote (Dish)
to set remote to tv
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
Apr 30, 2008 | DISH Network IR Remote Control
Vizio L32 HDTV 10A-remote
Try a new Remote control, and if that doesn't fix the problem, it may be a remote sensor in the set. Hope this helps. Have a great weekend
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
