Question about GE Profile CustomStyle PSI23NGR Side by Side Refrigerator
Where is the defrost timer located on my GE Model 20-27 side by side refridgerator?
  • 111 Answers
SOURCE: Defrost timer sticking
Your model doesn't have a defrost timer. Everything is controlled by the main motherboard in the back. The ONLY way to get an acurate diagnosis is to call GE FActory Service at 1-800-432-2737. There is proprietary software and the tech will be able to plug in a laptop to your refer to find out what is going on. No other companies have this or have access to this software. By the way that deforst thermostat you think you found isn't what you think it is. It looks like one but it only a saftey device. Trust me...!
Posted on Dec 16, 2008
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
SOURCE: Where is the defrost timer located on GE
This model does not have a defrost timer. It has a motherboard. You must jump out the plug to the main board to test the defrost circuit. In order to do this take the cover off of the main board, find the three wire connector on the base of the main board, connecter is normally blue in color. On the board itself it will identify termials as line, defrost, and compressor. To test you must create a jumper wire.Install the jumper in the plug terminals identified as line and defrost.This will turn the defrost heater on. If the heater does not come on, look for a defective heater or a defrost thermostat(mounted on the top of the evaporator). If the heater does come on replace the thermister(located on top of evap, white in color and has two white wires part#WR55x10025)
Posted on Jun 05, 2009
Maytag317
  • 1136 Answers
SOURCE: where is the defrost timer located on ge side bty
Hi, This model has a mother board instead of a defrost timer. If you are having a defrost issue, the first part you want to test is the defrost heaters. If you need instruction on testing the defrost cycle, please let me know so I can assist you further.
Thanks
Vic
Posted on Jul 15, 2009
spectaculusc
  • 321 Answers
SOURCE: Where is the water filter for the ice maker
Filters situated in the interior liner of the refrigerator compartment of GE-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Posted on Jan 26, 2011
Where is the defrost timer located on model GE GSS22JETG WW? This is a side by side
USUALLY LOCATED IN THE FRIDGE AT MIDDLE TOP BUT SOMETIMES CAN BE FOUND IN THE FREEZER ALONG THE WALL
Mar 08, 2015 | GE Refrigerators
Ge profile refrigerator PSF26PGTB defrost timer
your defrost timer on this model is an ADC type timer(automatic defrost timer) and is located on the mainboard in the lower rear on the back side of the unit,its part # is WR49X10152
Aug 25, 2012 | GE Refrigerators
I have an older side by side GE refridgerator model number TFXC222J. The freezer section is working but the fridge side is not cooling. light works.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | GE Refrigerators
My GE model tfx20jrxd is not getting cold on the refridgerator side but it is fine on the freezer side. There is some frost build up on the back wall of the freezer. Any suggestions?
you have a defrost issue. some problems
1. failed heat coil
2. failed defrost sensor
3. failed defrost timer
Please Rate/Vote this response. Thanks
Dec 20, 2010 | Refrigerators
Freezer side of refridgerator doesn't freeze foods properly and also makes only about 10 cubes a day. food side works fine, it's a Hotpoint model #HSS251FMB WW
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
Aug 17, 2009 | Refrigerators
Where is the defrost timer located on ge side bty side model gss25jfmdww
Thanks
Vic
Jul 15, 2009 | GE GSS25JFM Side by Side Refrigerator
GE Model number TFX25PPBE BB where is the defrost timer located and what does it look like?
hi..the defrost timer is located behind the control panel
in the refridgerator section.
check it out..
thank you..
kindly rate my response..
Jul 14, 2009 | GE Refrigerators
Freezer freeze up
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
Dec 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Eterna Series side x side refridgerator
Temperature adjust displays not showing, can not adjust temp, is something disconnected?
Dec 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Defrost timer
most newer refers have the timer located somewhere near the main controls. Usually in the console near the refrigerator thermostat. older models could be behind the kick plate on the bottom or even on some in the back near the compressor. If it's a new electronic model it may not have a timer.
Apr 22, 2008 | Refrigerators
GE Profile CustomStyle PSI23NGR Side by Side Refrigerator Logo
275 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
