Question about Kenmore HE2 Plus Front Load Washer
Kenmore elite h3 front load washer problem Washing stops and the washer has SUD flashing.
    President:
  • 1,430 Answers
Try this link it is usually a clogged filter or to much detergent F21 Fault Code Repair
Posted on Nov 09, 2010
My Kenmore Elite front loader keeps on showing the same problems
Cut down on your soap i only use very little soap and it works great.No more SUD code
Jul 02, 2014 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite h3 washer - Bad Water Pump?
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(located, and mounted on the actual pump)
If the above does not correct the problem replace the pump
Nov 02, 2009 | Kenmore Elite 45986 Front Load Washer
WONT RUN COMPLETE CYCLE WITHOUT F-2 OR SUD
sounds like you have a clogged/bead pump. removethe lower acess panel and from there youll see the pmp clean put remove thescrewout, and clearthe debris. BE WARNED THER WILL BE WATER BEHIND grab a towell or 2
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite Frontloading HE3 is flashing a Sud, what do I do
apply a small amount of cooking oil imside tub ,, must use only HE deteregent if you are ,,, maybe too much
Jan 01, 2009 | Kenmore 42822 Front Load Washer
New Kenmore Elite Front Loader will not get past 'Sud' cycle,
Hello wheeljc; I had the same problem when I purchased my Kenmore Elite in 2006. I have a HE4t front load. It's possible that you're using to much detergent, if you're using HE liquid it only requires a small amount and does a very good job.
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Spinning and draining does not work, F error or sometimes Sud
Sud means you using to much soap and the f code means soap is locking the drain pump up and wont allow unit to drain and spin.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
178 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
