Question about Dell Inspiron 2200 Notebook
My computer says I am only using 504 MB Memory instead of 512 mb, does anyone know why, using XP Professional on my laptop Dell Inspiron 2200
    Scholar:
  • 97 Answers
This is probably due to 'shared memory' that the video adapter uses.
There isn't much you can do about it, although there is an option on some computers and laptops to reduce the video memory that is used.
Please note: changing BIOS settings can give adverse performance effects, only change if you are confident you can go back in again and change the setting back to what it was (make a note of any changes you make, in case you need to reset).
To do this, you will need to get to the BIOS settings by pressing F2 when the computer is first starting up and you can see the DELL logo. Then look for Video settings (unfortunately I don't have an Inspiron to hand to say exactly where it is)... you should be able to change the video memory from 8Mb to 1Mb.
Save the settings, reboot and see if that has made a difference.
Hope that this is of some help.
Posted on Nov 09, 2010
  • Jay PFixIt Nov 09, 2010
    Thank you
  • Kevin Pawsey Nov 09, 2010
    You're welcome :)
    Hope that it solved your problem... don't forget to rate the advice if it was useful :)
What memory (does) it use?
Jokodi Haynes,
The Dimension 8200 memory specs are listed below.
Memory
Architecture RDRAM
Memory connectors four
Memory capacities 64-, 128-, 256-, and 512-MB non-ECC RDRAM
Minimum memory 128 MB
Maximum memory 2 GB with Microsoft® Windows® 2000 and Windows XP; 512 MB with Windows Millennium Edition (Me)
Memory type PC800 (non-ECC)
Memory speed 40 ns or faster
BIOS address F8000h
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 29, 2016 | Dell Dimension 8200 PC Desktop
How to upgrade ram on inspiron mini 1012
Anonymous,
Click the link below to download the online service manual. The manual will provide information on how to add/remove parts within your computer.
Inspiron 1012 Online Manuals
http://dell.to/1JCCann
Below are the memory specs for this system.
Memory
Min/Max Memory 512 MB /2 GB Memory Type DDR2-800 MHz Thank You,
Dell-Jesse L
Feb 23, 2015 | Dell Computers & Internet
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
Inspiron 2200 Memory Module not recognised
Are you sure its the correct speed/type of RAM? According to Google your laptop takes PC2700 DDR RAM, ensure you are using this in both slots to avoid problems. If you have it fully inserted into the slot and nothing happens when you swtich it on then the laptop doesnt like that type of RAM and you'll need to change it.
May 17, 2009 | Dell Inspiron 2200 Notebook
Inspiron 6400 notebook
There are two slots for memory on that laptop and it will take a maximum of 2GB of RAM. The memory type is 1.8-V SODIMM DDR-2.
The cover ont he bottom if the laptop is easy to access and add more memory.
Dec 31, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 1100 won't read 512 Meg ram.
I had the same problem. I tried several brands of memory unsuccessfully, though they all guaranteed that their products would work with my machine. Finally, my brother (who works in IT) recommended that I go through The Upgrade Place (http://www.theupgradeplace.com/). Great price - less than half of what Dell charges - and the memory worked immediately upon installation.
When I told them that I had a Dell Inspiron 1100 laptop, they said that my PC required proprietary memory (which is true). I paid with a credit card and received the part two days later.
Good luck,
Jay DeKing
Dec 27, 2008 | Dell Inspiron 1100 Notebook
Does my inspiron b130 laptop support s video output to my tv?
No. INSB130 does not support S-Video. Here's the complete specs of your system:
Processor type Intel® Pentium® M and Celeron® M
External bus frequency (front side bus) 400 MHz or 533 MHz
System chipset Intel 910GML Alviso
Data bus width 64 bits DRAM bus width Dual-channel (2) 64-bit busses Flash EPROM 512 KB Graphics bus Internal PCI bus 32 bits ExpressCard controller ICH6M ExpressCard connector One ExpressCard slot 54 mm Cards supported ExpressCard/34 (34 mm)
Expresscard/54 (54 mm)
1.5v and 3.3v Memory module connectors Two user-accessible SODIMM connectors Memory module capacities 256 MB, 512 MB, and 1 GB each Memory type 2.8-V SODIMM DDR-2 Minimum memory 256 MB Maximum memory 2048 MB Ports and Connectors :
Audio Microphone connector, stereo headphones/speakers connector
Mini PCI Type IIIA Mini PCI card slot
Modem RJ-11 port
Network adapter RJ-45 port
USB Three 4-pin USB 2.0-compliant connectors
Video 15-hole connector
Network adapter 10/100 Ethernet LAN on system board Wireless Internal Mini PCI Wi-Fi® wireless technology support
Video Type Integrated on system board
Video controller Intel Integrated Graphics Media Accelerator 900
Video memory Up to 64 MB of shared memory (when less than 512 MB system memory is installed)
Up to 128 MB of shared memory (when more than 512 MB system memory is installed)
If this is helpful, please rate it.
Dec 05, 2008 | Dell Inspiron B130 Notebook
How to upgrade a Dell Latitude CPX - Intel P3 500-650 laptop
I have a CPX H500GT. To get it to run XP Pro to run right, max out the ram. And get a larger harddrive. Xp uses a substantial amount of space.
Sep 22, 2008 | Dell Latitude CPX Notebook
Adding more memory to my inspiron notebook
The second slot on the 2200 is under the keyboard.
Jul 31, 2008 | Dell Inspiron 2200 Notebook
Inspiron 1150 Slow startup, slow printing, unable to run 2 programs at once
What Operating System do you run? If it is Windows XP SP2 (Home Edition or professional), here are some things you can do to speed up your system. 1st you should remove all programs that are not required from the start menu. Start > Run > Msconfig > startup tab. Unselect all that are not necessary. Also Right click on my computer > properties > Advanced > Performance settings > Adjust for best performance. This should speed things up a little. I would recommend atleast 512 MB of memory to run Windows XP and its applications decently. You should consider an upgrade.
Dec 20, 2007 | Dell Inspiron 1150 Notebook
Dell Inspiron 2200 Notebook Logo
110 people viewed this question
Clive
Clive
Alun Cox
