Question about HP LaserJet 1012 Printer
HP 1012 Laserjet. When I plug into USB port on laptop it starts searching for a driver. It says it can't find one. I go to HP and try to download driver and it does not work. I'd sure like to get my hands on a start up disc. I lost mine but I think that would solve the problem. I have Vista and have spent hours trying to get up and running.
  • 1 more comment
  • Rommel Alilin
    Rommel Alilin Nov 09, 2010
    Vista 64 or 32?
  • itldoranch Nov 09, 2010
    What was it about my going to HP and downloading the drivers and NOT having it work did you not understand? It never asks me to RUN the download. As I stated, I have tried the link you sent me several time and I cannot get it to work.
  • itldoranch Nov 10, 2010
    Do I have to clear each tmp file individually? It took forever but there was 2 I could not delete. One labeled Low and the other RTKBTMNT (Realtec audio). I've tried everything and it seems the driver I want is labeled lj1010serieshb-vista32.zip so I managed to put it on my desktop. When asked to browse I've tried everything. I put C:\Users\Keith\desktop\jl1010 bla bla, and it says that is a bogus location. I need a friggen start up disk or another printer. This is BS. Do you have any suggestions? There was never anything in my temp files with a 7z in it. Nothing. I checked every file.
  • HP Master
  • 1,679 Answers
You need the drivers to install the printer on PC.
Click on the link below to download the drivers and install
After you have downloaded the file, run the file and complete the installation. Later connect the PC.
Download link
Thank you for contacting FixYa
Posted on Nov 09, 2010
  • 3 more comments
  • ONE-Touch-Solution
    ONE-Touch-Solution Nov 09, 2010
    Download link
    Click on START
    Right click on COMPUTER
    left click on PROPERTIES
    From the Window : Check under System Type : it should display as 32 bit operating system or 64 bit operating system
    Close the Windows
    Click on the link to go to the download page to download the Drivers
    Download Link
    Before you download, Clear the temporary folder
    Click START
    under START SEARCH ( or RUN option )
    Type "%temp%" ( without quotes) and hit enter key
    Delete all the files and folder you find in ( they are all temporary files and no harm if you delete them )
    Download the software/drivers from the given link above and run the installation file
    Later open the same %temp% folder and you will find a folder created ( maybe 7z name )
    Copy the folder from temp folder to desktop
    Now connect the printer to PC
    If it prompts you to locate the drivers by browse option
    Give the location to the 7z folder and click ok
    It should install the software without a problem
    ONE-Touch-Solution Nov 10, 2010
    Do let us know if the problem is solved.
    FixYa Team
    You have the Zip file downloaded so once you run the zip file. it will extract the actual contents of the software ( just like you find in software disk ). It will create a folder and when the Wizard is prompting you to locate the drivers, give the location to the folder it has extracted.
    To unzip, you need WinRAR or WINZIP software in your pc. You cannot delete all the temp files so do not worry if one or many files are left undeleted.
    Have you tried to use the option LOCATE DRIVERS IN MY COMPUTER when you get the wizard screen asking for Drivers ?
    Were you able to resolve the issue ?
    FixYa
My HP LaserJet 1012 printer won't print. I've checked spooler and nothing is in there. I've rebooted computer and printer.
Assuming that you are using windows platform, when USB cable removed and inserted, computer must make a sound signaling a USB device is inserted. If no sound or visual experienced, try another USB port and/or change cable.
Otherwise, (also assuming that there are no warning lights on the printer) you may want to rremove printer queue and re-install the driver.
Good luck
pls vote so I may continue sharing
Nov 10, 2010 | HP LaserJet 1012 Printer
HP Laserjet 1012 printer not recognized
I really don't understand your problem as you stated it.!!
Your printer worked on your old system.. What was your old system ?? XP, XP Pro., 32 bit or 64 or VISTA. VISTA home 32 or 64.
If you are having problems installing the printer, it is not the fault of the Manf., you may not be loading the correct drivers.
First, check your device manager and see if the printer is being seen. Next, go to your printer icon and remove any printers installed.
Next, disconnect the printer from the unit and reboot.
Now, you have a unit free of any printer entries.
Find the software for you printer and if it is the correct version software for your printer, install it.
During the installation the software should tell you to plug in the device to a USB port.
Make sure the port you are using is the same as you have used before, as you may not have the support needed with another USB port. example,
port in the front may be a USB 1 port, the USB ports in the rear may support USB2 devices.
Next, if the software has loaded correctly and you have had no problems during the installation, you should be able to run your printer.
You should be able to find the correct drivers for your printer @ hp.com
I hope this has helped you !!!
Sep 26, 2009 | HP LaserJet 1012 Printer
HP Laser 4L driver for USB port
Not all USB adapters are the same, you need the one that is made for your printer, I would try a different adapter before going too deep, because when you plug it in your computer should see it even without drivers.
Jul 21, 2009 | HP LaserJet 4L Printer
How do i install my hp laserjet 1012 without the disk
If you have internet connection to the machine, then download the driver for the appropriate operating system. If you have already tried to connect the device without installing the driver, first, then remove the cable from the printer, and download the driver from http://is.gd/1jBZ9 and install the driver. WHEN THE INSTALLATION tells you to connect the deivce or when it tells you it is looking for it, then plug the USB connector into the computer, and plug the power line into the printer. It will eventually find it.
You have to be patient with all HP driver loads and WAIT for the install routine to ASK you to connect to the pc / mac.
Jul 01, 2009 | HP LaserJet 1012 Printer
How do i install the hp laserjet 1012 printer without a disc
I have the same printer. Excellent machine. The printer driver can be downloaded from HP's website.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=306510&lang=en&cc=us&prodTypeId=18972&prodSeriesId=377934&taskId=135
Here is a direct link to where you can select your operating system and then download the driver. You'll be using it again in no time! ;-)
Jun 05, 2009 | HP LaserJet 1012 Printer
Can't install old HP Laserjet 1100 using a USB cable
USB cables are just that. No drivers are needed. What it is searching for are the drivers for the device that is plugged in via the USB cable.
Follow this link to find the drivers you need for the printer on your operating system:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=LaserJet+1100&submit=Go+%BB
Apr 20, 2009 | Acer Aspire 5315 Notebook
HP laserjet 1012 printer not working with Windows vista.
Let www.hp.com auto-detect your printer and download the driver automatically.
Jan 01, 2009 | HP LaserJet 1010 Printer
HP LaserJet 1012 Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
