Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
Standby light Get Standby light flashing 4 times... will not come on
    Sergeant:
  • 243 Answers
It is indication you have a failed ic. replace the 2 main ic components on the D-board. r two ic's with ic-8002 ic 6501 both are mcz3001D IC's they cost 5.50 each. Have a proffesional that can do soldering to the board and your fine. If not take it to a technician to replace the IC's on the dboard that are faulty.
Posted on Jun 16, 2008
  • Sony Master
  • 8,617 Answers
IC 5004 is faulty on the D board and has caused loss of vertical deflection which is Sony part # 8-759-696-71 the actual IC part number is STV9379A and you should be able to get one at the following link.
http://servicemanuals.vstore.ca/
  • Sony Master
  • 13,433 Answers
This indicates that there is a problem with the backlight of the LCD-panel. Most of the time the inverter unit is defective.
In rare cases, the backlight is not switched on due to a problem on the BDT-board.
  • Ekse Jun 16, 2008
    there may not be replacement parts available in which case the complete LCD panel has to be replaced.
  • 4,472 Answers
Ok sounds like you need a technician to look at it due to a transformer failure. Keep me posted
Thanks,
Lee
  • 5 more comments
  • Lee A.
    Lee A. Jun 16, 2008
    Also are you sure it is blinking 4 times. Could it be 3 times?
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 16, 2008
    I would advise not soldering it yourself though and having a certified technician. Knowing what the parts cost the job will not be very hard.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 16, 2008
    2 IC's are bad on the main board they are part MCZ3001D IC.
    they are 5.50 each.
  • Lee A.
    Lee A. Jun 16, 2008
    sorry I meant they are on the D board.
  • Lee A.
    Lee A. Jun 16, 2008
    In any case a Sony authorized repair center would be the best place to bring it to. As replacing any and all of these IC's may not correct your problem.
    I hope that you will find this helpful,
    Lee
  • Lee A.
    Lee A. Jun 18, 2008
    I believe your problem has been solved to the best of anyone's ability. If my solution was helpful I would greatly appreciate that you accept and rate accordingly. If I don't hear from you I will assume that you are more then satisfied.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 19, 2008
    Still hoping to hear back if you needed anything else. If you get a spare moment and could accept and rate my solution accordingly it would be greatly appreciated.
    Thanks,
    Lee
3 Suggested Answers
needi
  • 55 Answers
SOURCE: Sony KP-53HS10
The problem seems to be in Secondary supply of Switching Power supply.
Posted on Apr 08, 2008
  • 3 Answers
SOURCE: TV doesn't turn on, standby light flashes 4 times
4 flashes mean the IC5004 (STV9379)on D-Board went bad and the 15V supply is no longer steady. The IC is rather easy to find and inexpensive (around $2.50). Your main problem will be desoldering the old one and soldering the new one. CAUTION! - Heat sink on IC5004 is -15V. Care must be taken not to allow heat sink to touch any other components
Good Luck.
Posted on Jan 04, 2009
My Baird jo47 won't turn on and the standby red is flashing with sound what is the problem
My baird JO47 tv is stuck on standby - Digital TV - Streaming ...
www.tomsguide.com/forum/55998-4-baird-jo47-stuck-standby
Dec 17, 2012 - 4 posts - ‎2 authors
My Baird JO47 tv is stuck on standby and won't come off. ... I have a panasonic 50" TV it will not turn on no green light or standby red light ... Forum; my tv standby light keeps flashing blue on and off and won't switch on Forum ...
Baird JO47 Stuck on Standby ' Electronics Forum (Circuits ...
Dec 15, 2015 | Televison & Video
Standby light blinks 4 times
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 01, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
4 fast blinking lights
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
Oct 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Will not come on. red light flashes 4 times
Never a good sign when you have red flashing codes
4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
Please rate my help++++Thanks for using FIXYA
May 28, 2010 | Sony KDS-50A2000 50" HDTV
Kdf-60xbr950 no pic or sound. standby light flashing
Sounds like the lamp is bad. Might be time to replace the TV.
Mar 31, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
119 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
