Hyundai Motor 2002 Elantra Logo
Posted on Nov 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can the error codes be determined by a pin out like some of the older cars or do you have to have a scanner for a 2002 Hyundai elantra?
Anonymous
Level 3:
President:
  • Hyundai Master 2,050 Answers
  • Posted on Nov 09, 2010
Anonymous
Hyundai Master
Level 3:
President:
Answers
2050
Questions
0
Helped
710606
Points
6446
I need the location of Fuel cut off relay in a 2002 hyundai elantra
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
1helpful
2002 hyundai elantra where is the connector located for code scannner?
it should be located under the dash on the drivers side of vehicle
2002 hyundai elantra gls . low idle speed, check engine light on, and doesn't shift out of low gear . ( 50,000 ) miles
Did the 'Check Engine' Light come ON? Whenever the 'CHECK ENGINE' light comes on, the ECU (Engine Control Unit) sets a Diagnostic Trouble Code (DTC). These codes identify the particular engine management system which caused the light to come on. You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code which have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE and perhaps eventually fix the problem.
4helpful
2answers
I have a 2002 Hyundai Elantra, I changed the battery , now I need the reset code for the CD player HM 5064. I cannot find my manual. Can anybody help?
Normally the Audio (Radio CODE) is noted in the owner's manual. If you don't have it, you must contact Hyundai Motor America and give them the Vehicle VIN number... they may then (possibly) be able to give you the CODE.
Hyundai Elantra 2002 doors clicking and popping
Check the play in the door pin hinges by lifting up and down on the end of the door if there is excessive play or up and down movement the door pins must be replaced, I have had cars make this sound because of worn hinge pins.
How can i get a pin code for hyundai Elantra 2003 . please
contact ehyundai with the V.I.N and they should be able to help you.. i am presuming it is for the stereo.
Sudden hesatation, loss of power, 2002 Hyundai Elantra
P0715 is the imput speed sensor is open or shorted. The P1529 is the transmission control module(computer) requsting the check engine light to turn on. These sensors are prone to going bad.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
