Question about Black & Decker Garden
Mouse sander just gone dead! Could this be brushes?
    Brigadier General:
  • 4,088 Answers
If the machine has seen considerable use, brush failure is a possibility. If the machine is AC powered, the plug end of the cord can sometimes fail--just cut the cord end back a little and install a replacement plug. If it is battery powered, the battery may have lost charge or there is an intermittent connection. Good luck!
Posted on Nov 09, 2010
Durabuilt 3"X21" Belts Sander Brushes. Question: Should I replace brushes or buy new sander?
If the sander is otherwise in good shape, and hasn't been abused, I'd replace the brushes.
Jul 11, 2014 | Greenfield Industries Measuring Tools &...
Can't figure out how to load the sand paper on to the mouse sander
Just stick the sand paper sheet to the base of the mouse sander... it's velcro it will hold... match the forme of the paper with the forme of the sander's base... that's all...
Cheers!
Aug 06, 2011 | Black & Decker Mouse Sander/Polisher
Burning Smell then spark and now it dosen't work
sounds like the brushes wore out on the inside and then burnt, check the inside brushes but if it looks burnt when you open, it is a lost cause
Jan 18, 2011 | Black & Decker Mouse Sander/Polisher
The belt on the sander doesn't turn. The sander has power when plugged in and the motor runs when you press the button. But the Belt and track don't turn.
Likely the gear belt that drives the drive rollaer has failed. Either it is totally gone or the teeth in a spot have been destroyed and the motor is just spinning the sprocket in the belt. The belt is about 1/2 inch wide and is covered by a belt guard.
Jun 13, 2010 | Makita 3 x 24" Belt Sander
Do you get brushes for the motor of a KA150K mouse sander? Are they easy to fit? Could you supply an exploded diagram of the unit? Thanks
I would go to Dewaltservicenet.com and download a breakdown for this tool and also you can find a local dealer in their locator section.
Jun 08, 2010 | Black & Decker Mouse Sander/Polisher
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
Dewalt DW433 belt sander stop working, why? While sanding shutters, my sander just stopped. Any fixes?
Check the brushes for the motor they may have gone bad or broken, I have seen this happen before on dewalt tools.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Apr 02, 2010 | Dewalt DW433KT Heavy Duty 8 Amp 3 Inch By...
Belt sander
You're plugged in to a dead outlet, OR the rotor brushes are not in contact with the rotor, OR the power cord is partially severed,
Jan 06, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
Can I get new brushes for my B&D mouse sander
Hi there
Try the link below
http://www.blackanddecker.com/CustomerCenter/ServiceCenterLocator2.aspx
The link will show you a service center locator , just type your zip code and give them a call with model # and serial # to get the parts you need .
Hope this help
Sep 02, 2009 | Hand Tools
Dead. Power is connected, wires are in tact. Just died when I was using it. Is ther an internal reset?
Try to plug something else into the outlet, just to make sure that the breaker didn't trip.
Try to run the sander without a belt. It may be in a bind.
With the sander unplugged, check the motor brushes. Replace if necessary.
If everything above checks out OK, you may have a loose wire.
Regards, --W/D--
Jul 13, 2009 | Ridgid 3 X 18 Belt Sander
Garden Logo
54 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
