Question about Zebra P330i Thermal Card Printer
Will not print a valid barcode. -black on part on the barcode, or red/yellow, etc
    Champion:
  • Zebra Expert
  • 285 Answers
Go to driver and send command "!SA, is possible that fix the problem.
Posted on Nov 12, 2010
When i try to print in color, the red prints as yellow..i am not out of ink
Most printers have 4 inks: Magenta, Cyan, Yellow, and Black. Red requires the printer to print both Yellow and Magenta. If your Magenta isn't printing, red will show up yellow. When you say, "I am not out of ink", you may actually BE out of Magenta, or your magenta ink nozzles may be clogged. I don't know what brand of printer or model you have, so I can't give you exact directions to clean the nozzles. The printer driver may have that ability.
Dec 17, 2016 | Office Equipment & Supplies
Preventing barcode scanner from rading photocopied barcode
put a red background, so that b/W prints will be black. Nothing can prevent color copies to be made though...You casn always develop an app for validation.
Feb 24, 2014 | Datalogic QuickScan Computers & Internet
Free wiring diagrams
Original sound system could have had an internal amplifier or separate amplifier. The most practical approach to finding what goes where would be to find a library that subscribes to the EBSCO host automotive repair reference center (ARRC) and print the diagram.
May 15, 2017 | Toyota Celica Cars & Trucks
Troubleshoot tec barcode printer
Download windows driver from www.bartenderbarcodesoftware.com
define the pages et label size in the driver, check that you have validated the coreect use (direct or thermal transfer) gap, black mark etc..
Once the driver install , you can use ssdal send file.txt to snd a file to the printer. Check with the help /? option
Nov 21, 2013 | Toshiba TEC B-472 Thermal Label Printer
I am printing in red but output is yellow
Check the ink levels- it sounds like your Magenta is out- HP deskjets use CMYK to mix the colors- C = Cyan, M= Magenta, Y = yellow, K = intensity (black). Red is usually a blend of Magenta + Yellow- so if you don't have magenta ink in your printer, when you try to print out something in red- it will come out yellow
Jul 01, 2011 | HP Deskjet D2360 InkJet Printer
8110 printer stops printing after running the yellow and red colors...will not feed paper back in to finish with the rest of the printing...not sure what to do
It sounds like you may have a damaged ribbon (transfer film)
Take out the cartridge and with the barcode side facing you, turn the left spool (takeup spool) counterclockwise until you have seen a complete square of cyan (blue) and magenta (red) and yellow (actually yellow) go past, and then reinsert the tri-color cartridge.
Feb 27, 2011 | Kodak Picture Maker Kiosk Printer
How can I wire fluorescent tube light.There's 2 cables incoming through the wall.One has red,black and green/yellow.Other has red and black only.I've tried connecting both reds from the incoming cables to...
if you have 1 switch ! take the cabel wiv the yellow red black an green conect green to E earth , conect the to reds together that will feed the switch connect the black to the nutral on the light fiting and tape up the yellow not needed !,then take the cabel wiv only red and black , the red is connected to the other red as explaind above ,then the black is the return from the switch therfor connect it to the live tuminal on the light fiting MAKE SURE U TURN IT OFF AT THE FUSE BORD FIRST PLEASE!!!!!!!!!!!
Sep 29, 2009 | Hydrofarm Hydrorfarm Flco200d Fluorescent...
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
TLP 2844 won't print barcodes
The printer is in line mode. Do the following to take it out of line mode:
Turn printer power off.
Hold the feed button while turning printer power on.
When the light starts flashing, release the feed button.
When the light starts flashing again, press and hold the feed button.
When the light turns steady amber, release the feed button.
When the light turns steady green, the mode is changed.
Verify the mode by printing and inspecting a status report.
This requires good timing and may take several tries. You'll know it worked if no labels are reeled out after you're done.
Apr 10, 2008 | Zebra LP 2844 Thermal Printer
Zebra P330i Thermal Card Printer Logo
65 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
