I replaced the belt on my dryer and a day later it stopped heating what could this be?
  • Washing Mach... Master
  • 1,902 Answers
Hello
Thermal fuse which is located inside the back cover panel on the blower wheel housing causes no heat issue in the dryer. Please check it for continuity, you can take a multimeter and test it for continuity between its two pins, no continuity= bad fuse and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Nov 09, 2010
Dryer has no heat
I have one of those Kenmore "Laundry Center" stacked washer/dryer units. It comes built that way - it is not two units stacked on top of one another (if there is such a thing).
My guess is that it is at least 13-14 years old now (it came with the house I bought) and about 3-4 years ago, it also stopped heating. The dryer would run for a couple of hours and all of the clothes would still be damp and the air in the dryer was not warm or hot.
I searched online and found that the usual cause is the heating element wire was probably burned out if the dryer was otherwise running all right. I found some repair instructions online and the procedures to take the dryer apart (can't recall where - just Google it).
The heating element is like a long coiled resistance wire, similar to what you would see in a toaster but heavier duty. It is strung in a circle behind the dryer drum tub to heat the air that enters the dryer.
If you've ever looked into a toaster when toasting, you'll notice that that thin resistance wire glows red hot which generates the heat. Now imagine that thin wire being red hot and the dryer tumbling, causing constant vibration. It's amazing that the heater resistance wire doesn't break more often!
A pretty handy DIY-er can take the dryer apart and replace the heater wire, but the challenge is getting the stacked unit out in the open somewhere where you can work on it. You need a fair bit of room.
My advice would be to also buy the drum belt replacement kit to also replace that at the same time. If you're going to go to the trouble of taking the dryer apart to replace the heater wire, you might as well replace the drive belt and associated felt pad, etc. at the same time. You DON'T want to have to take the dryer apart again a little later to change that part when it breaks. (It's like a timing belt on your car - if you're doing major work on your car and have the engine apart and it's "about time" to replace the timing belt per the manufacturer's maintenance schedule, might as well do it a the same time to save on repeating the labor again.)
Apr 05, 2014 | Kenmore 98702 Stacked Washer/Dryer
If my Samsung dryer belt was loose but still turning, will it stop the heat element? Because I had a problem earlier in the week with it heating. I took the back off and noticed the belt was freyed
Yes if the air flow is reduced because of a slipping belt that could cause the heating element to turn off due the temperature sensor being a high input. Remember the motor runs a fan as well as the dryer drum.
Jan 20, 2012 | Samsung DV218AEW Electric Dryer
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
I have a whirlpool dryer that will spin but will not heat or shut off automatically?
some dryer 's have belt sw on them if belt breaks dryer stopes ( no spin ) if dryer stops no heat . replace the belt and it should work .. other problems / ck the power if 220 you may have lost 1 leg . dryer will go but heat and will not shut of auto . mm
Dec 09, 2009 | Dishwashers
Dryer will heat up but drum will not turn. Unable
Good day,
Sounds like a broken belt, Excellent tutorial on changing the belt on the link below.
Caution: Some models used a very poorly designed belt tensioner. If the tensioner is that style, replace it while purchasing the belt.
Appliance parts house counter men are well aware of the problem. The Roper line is made by whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 04, 2009 | Roper REX4634KQ Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Simpson Sirocco 350 Dryer not heating
there is an oval cover on the back of the dryer. Remove this cover and you will probably find a broken fan belt. A replacement costs about $20 Aus.
NOTE: If you have been using the dryer for a while in this condition there will certainly be moisture inside the dryer. Replace the belt and leave the dryer for a few days to dry itself out (motor and electricals) before firing it up.
Oct 08, 2008 | Maytag 7.0 Cu. Ft. Electric Dryer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
