Question about John Deere Garden
Instructions for replacing starter solenoid on a John Deere LX176 (Kawasaki).
5 Suggested Answers
jmgldsmth
  • 1869 Answers
SOURCE: instructions to replace starter on JD RX75 lawn mower engine
AM102628 STARTER MOTOR insert starter place bolts into lug holes in starter thread into matching holes on the engine (if bolt is too long and, bottoms out try another bolt
attach wires to the solenoid you're done
torque the bolts to 35 foot lbs.
Posted on Sep 05, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
rwvanlue
  • 486 Answers
SOURCE: Starter solenoid on John Deere (Kawasaki) 17 hp engine
It hooks onto the fork.
NOTE: Remove the plunger from the solenoid.
Move the gear to position the fork as close to the solenoid plunger as possible.
Hook over the fork,
Re-insert plunger into solenoid
'a light film of grease could be applied to the plunger, but not TOO much'
Posted on Nov 20, 2009
Tip
Mower belt diagrams 2
john-deere-54in
John-Deere-CA130
John-Deere-Gt235-54
John-Deere-LX176
on May 20, 2015 | Garden
How to remove the old lower hood on a john deere lx178
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
JOHN DEERE LX172 LX173 LX176 LX178 LX186 LX188 LAWN GARDEN TRACTOR Service...
Apr 29, 2017 | John Deere Garden
John deere x540 with140 hours. Jump started from storage and cut 2 hours without issue. would not crank back up. Installed new battery and checked fuses. Lights and all come on but will not crank.
would not crank Chet, Relay,Solenoid or starter may be defective, give the starter a sharp bang with a hammer, to see if it is stuck.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Test lawn Mower Solenoids
How To Test Solenoid with Taryl
Electrical System Troubleshooting for Lawn Tractors Mowers
JOHN DEERE KAWASAKI RELAY
Mar 30, 2016 | John Deere Garden
Need carburator ajustment / john deere lx176/14hp kawasaki
i have 14hp kawasaki that backfire throw the carb and exhaust what could it be
Jun 05, 2012 | Garden
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
Have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Aug 10, 2009 | John Deere Mower Blade 5 each
John Deere 185 Hydro won't stay charged
I had the same problem on my lx176. Check all your connections first. If they are all ok and fuse and fuse link are ok, unplug your magneto connector. Mine is a 2 prong plug by the dipstick tube. Connect a voltmeter to the engine side of the magneto and set it to AC VOLTAGE SETTING.. With the engine running I think I remember it should be putting out about 30 volts AC. If you have close to this voltage there it is probably your voltage regulator. Mine was. Hope this helps
Apr 24, 2009 | Garden
Garden Logo
633 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
