Question about Sony STR-D865
Sound quit and display shows PROTECTOR Sony STR-D865
    Novelist:
  • 87 Answers
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic.
1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Posted on Nov 10, 2010
Sony STR-D865 Has no display or sound from any speakers
Fuses don't tend to blow on their own. The chances are that there is an overload somewhere. Caused by a shorted part.
There's a video on YouTube of this model and it is full of STK chips mounted on heat sinks. Check all of them out. Look for signs of damage such as burning.
May 10, 2018 | Sony Audio Players & Recorders
Sony GX800ES protector
Make sure none of the speaker wires are touching each other. If they are, it will short out the stereo which triggers protection mode and cuts out all of the sound.
Sep 21, 2007 | Sony STR-GX800ES Receiver
The display shows PROTECTOR and there is no sound
This means that the amp has detected a short, or low impedence and has shut down. check all the speakers for bad connections and shorts.
Apr 18, 2015 | Sony Stereo Reciever Str-d1090
How do you fix the dull display on Sony receivers?
No. The display tube itself would probably need to be replaced.
Apr 08, 2013 | Sony STR-D865
Sony str-ga7es stereo receiver/surround sound amp. Turn on and "protector" shows in the display. instructions say fix short. Not much help. ideas?
unplug it discharge output voltages with a 1k resistor then resolder the voltage driver ic's these ic's start with up, ie upc2558 , or stk350 etc. you will see the solder rings and cool solder joints around then. Use liquid flux and solder them back to the board. You might end up replacing them but youl never know until you try soldering them first. Larry's Electronics. ledstiles@hotmail.com
Apr 24, 2010 | Sony STR-GA7ES
When i turn up volume on receiver it display protected and then i loose sound on my sony str-d865 receiver
That's a protection circuit in the output of the speakers. It indicates a short, or abnormally low resistance of the speaker itself. Disconnect the speaker wires from the unit, and see if the message goes away. If it did, you have a problem with your wiring, or the speaker itself.
Mar 13, 2010 | Sony Audio Players & Recorders
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
No audio through speakers and no light on volume dial of Sony STR-D865
unplug it back in went into safe mode it sounds like gotta watch those kids lol unplug from wall 10 min try pluging back in ok if not blow fuse inside
Jan 24, 2008 | Sony STR-D865
What power rated speaker shoud I use with my str-d865
Sony STRD865 Home Receiver - Dolby Pro Logic - 1995 Related Models << STRD665 ($300) | STRD965 ($400) >> Here's the specs, see below but looks like 100Wx2 speakers at 8ohms. Features: A/V remote; Digital Signal Processing w/ 6 soundfields (Dolby Surround, Hall, Theater, Stadium, Game, Acoustic), Soundfield link; 30 presets; 4 audio/ 4 video inputs (1 tape monitor); sleep timer Specs: Stereo: 100w x2 into 8 ohms (20-20k Hz) at 0.3% THD; Pro Logic: 100w x3; Surround: 25w x2; subwoofer preout; FM sens. 11.2 dBf; 17" W x 5 3/4" H x 14 1/2" D Hope this helps!
Sep 14, 2007 | Sony STR-D865
229 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
