Question about Maytag MSD2651 HE Side by Side Refrigerator
When you press the ice bouton it makes a loud sound and nothing happens. we than open the door, close it and press again and it works
  • 316 Answers
Is this a loud banging noise? sounds like the solenoid for the cubed ice, this is normal. If you put the selector on crushed, you should not hear that noise. If however the auger motor operates after the door is opened, it sounds to me like you may have a loose wire at the bottom of the door. I've seen this on kitchenaids and whirlpools, but since they now own maytag, i may start seeing it there too. If you remove the toe plate underneath the doors, you will see your plastic water line going through the hinge and into the freezer door. You should also see some wires, possibly encased in a black mesh sleeve. When Ive seen issues like yours, the wires are so securely fastened to the frame and the hinge, there is no slack for the wires, and they have a tendency to bend in one spot, causing the strands of wire to break. Its possible for the strands to be somewhat frayed, and the insulation to still be intact, so visual inspection may not be enough.But you will still have to cut away the black mesh sleeve to expose all the wires. You will have to test the wire(s) with a piercing type probe, which pierces the insulation with a small pinhole. When I've encountered this problem, ive noticed the fraying occurs about 2 inches from the bottom of the door, so put the probe as close to the door as possible, and the other probe near the plug, which you should have unplugged, and is located under the freezer, but can be easily pulled out. The proximity to the door makes it difficult to test, and to repair, but it is possible, if you take it slow. When repairing these wires, it will be necessary to use an inline crimp style connector, which looks like a small blue tube when you are looking for them at your local hardware store. When you are done, wrap the wires in electric tape, similar to the sleeve you had to cut away, but do not fasten them to the frame with the plastic screw on loops that you will have removed to cut away the sleeve to begin with. This will alllow the wires room to move with the opening and closing of the door.
If you do not have the above described situation...you mean i typed all this for nothing? :) ...then you have a loose wire or connection for the auger motor somewhere, the auger motor is what rotates the corkscrew inside the ice bucket. Or you have an intermittent issue with the dispenser control board.
At this point, I would recommend you to call a local refrigerator repair company and have them inspect your problem.
Posted on Nov 09, 2010
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Some fan making a loud noise. When open either
It sounds like it is probably your evaporator fan, seeing as that fan will cycle off when the door is open, and resume when you close the door. Either some how something got in to it, or it is going bad. Hope this helps
Oct 07, 2009 | Refrigerators
Both the refrigerator and freezer are set to the recommended temperature, however, the refrig unit is making a loud humming sound. This sound stops when you open the door, but begins again when it is...
There is a fan that blows cold air into the refrigerator. It usually stops when the door is opened. Check to see if it might be frozen with ice if the humming sounds abnormally loud. Usually if it freezes up you cannot hear the fan running and the refrigerator will not get cold enough.
Aug 25, 2009 | Refrigerators
I have a GE side by side fridge. Model # GSH22VGRBWW It does not make ice. We was purchasing bagged ice and putting it in the ice dispenser tray and we could get ice now it will not release the ice. You...
Remove the ice bin,with the freezer door open ,press the pin switch at the top of the door opening, then press the ice dispenser ...if the forks on the auger motor rotate its ok... if they dont the motor is frozen
Jun 28, 2009 | Refrigerators
GE Profile making knocking noises at different times
I have the GE profile Refrigerator with ice maker in the refrigerator compartment. Mine was knocking loudly for long periods of time, so I finally removed the icemaker by removing the side panel in the icemaker compartment held with 1 phillips head screw, disconnecting the electrical plug (unclip), pulling the tab of the icemaker down (on top) and sliding it toward the door, thus removing it. There was ice frozen in the motor compartment that was the problem. I let it thaw out and re-installed. All was OK after that..
Jun 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Making a loud noise
yes. is the fan hitting ice. the fan activates when close the door the upper baskett press the fan and light switch............... good luck.......... LEAVE YOU COMENT IF IT WAS GOOD FOR YOU
May 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 13, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer defrost all. RS2556
The most likely is that the door was not closed properly, this is very common on this model, what happens is that the door closes against the freezer contens and therefore appears closed, this allows warm air into the unit which starts to melt the ice, if this should happen again it is a good idea to completely defrost overnight with the doors open and then re start the next morning as ice often builds up behind the rear panel. Regards Advisor
Jul 04, 2007 | Samsung RS2556 Side by Side Refrigerator
Ice Maker Making Noise
The motor for the auger drive runs pretty slow (about 18 rpm), it could be the drive is running continuously (unless the door is open). Check that and let me know some more info, is the noise real loud, soft, etc. Can you feel anything vibrating or running when the door switch is pressed in?
Nov 05, 2006 | Amana ASD 2624 Side by Side Refrigerator
Maytag MSD2651 HE Side by Side Refrigerator Logo
88 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
