Question about Kenmore Dryers
Well I just replaced the timer in My Kenmore dryer and yet it is still trying to go but doesn't. What could it be?
  • Kenmore Master
  • 2,699 Answers
Sounds like the motor is bad,open the door,hold in the door switch with one hand and spin the drum with your other hand,have someone hit the start butoon while you're doing this,sometime you can give the motor some help starting but if it starts you still have to change it out.let me know what you find
Posted on Nov 09, 2010
  • Sal De Nov 11, 2010
    also check the door switch,open the door and push in the paddle,if it doesn't click the switch is bad,i would check with a meter and make sure power is going to the timer,the motor and the thermal fuse,if the fuse is popped it won't run,if the dryer had alot of lint in it most likely it will be the thermal fuse located on the blower wheel housing,you have to clean out the duct that the lint filter slides into,blow out the vent line i use a leaf blower and vac out the cabinet where the motor is
3 Suggested Answers
  • 76 Answers
SOURCE: elect.dryer
waterbug The part number 696876 for the timer is still good part number. It is still available and it did not cross to different part number. Why you had to get the timer with different part number? If you will give me the complete model number for your dryer I can find for you the right timer and the best deal to buy it. Gendos.
Posted on Feb 06, 2007
  • 87 Answers
SOURCE: Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Posted on Jun 13, 2007
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My fridgidaire dryer (gas) stops functioning throughout a timed cycle - I then reset the dryer timer and it doesn't want to operate again. Other than calling a tech to come fix the dryer, what t
Probably the motor behind the knob. I replaced mine in a Kenmore recently. No big deal for someone with average skills. Go to washer/dryer forums. Lots of them. This will have a ton of solutions. Try YouTube
Aug 06, 2013 | Dryers
Kenmore Elite Heavy Duty King size capacity Quiet Pak 1 dryer doesn't turn on
Check to see if the door switch is working. When you push and release it, it should click. If not, it will need to be replaced.
If the switch is good, then the only other component that would cause that problem is the thermal fuse. If you could post your model number I could direct you to the part you need.
Oct 15, 2012 | Kenmore Dryers
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Dryer timer not working on a kenmore dryer model 80 serious
HI, if this device isn't working, you will need to replace it. it cannot be repaired. it is designed to fail and when it fails, you will have to replace the entire timer control module.
This device control all aspects of the cycle you initiate.
May 23, 2009 | Kenmore Dryers
Buzzer wont quit
have you tried to turn the knob slightly at end of cycle to see if it would shut off? try that if it does shut off then replace your timer
Jan 06, 2009 | Kenmore 73952 Gas Dryer
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Apr 14, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
29 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
