posted by bartolinii on Jun 16, 2008
The wireless assistant on my hp C310EA lap top, can not dettect the network despite the fact that the router is on and wireless assistant is enabled. please help.
Solution #1
posted on Jun 16, 2008
Hello there.
This is a common problem. What i typically do on notebooks that use Intel Wireless, is install the latest drivers and Intel software from their website. 9 times out of 10 this will make it pick up a network that was not previously found, or fix problems with timeouts and so on.
Please click here then choose your version of windows, click 'Go!' and then click "Download" beside the section called "Intel® PROSet/Wireless Network Connection Software for Windows* XP/2000 32-Bit"
When you download and run this file, and install the software, you can then use the Intel utility to connect to the wireless network.
Hope this helps.
Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Intel PRO/Wireless 3945ABG Network
Email this problem
Email this problem
Can you Help with these Wireless Adapters problems?
Wireless Adapters
how to set up brother mfc-465cn...
i only have one phone line . i... Answer This...
Wireless Adapters
VMCLite: No n/w activity after...
I can connect with VMCLite, but... Answer This...
Intel PRO/Wireless 3945ABG Network Connection...
I downloaded the new driver... Answer This...
Repair Service
Find Wireless Adapter Repairman Near You:
