Question about Kodak EasyShare C875 Digital Camera
Kodak eashshare c875 died, won't turn on with new batteries. (uses AA and have replaced them twice.) I have pictures on my internal memory that I want to download. Camera is old and needs to be replaced, but would love to have the pictures. Thank you.
SOURCE: What to do when camera (Kodak C875) memory card full
Try formating your memory card. Should be somewhere under your settings menu
Posted on Jan 18, 2009
shockwave727
  • 262 Answers
SOURCE: My C875 Kodak Camera will not read the memory
make sure that the internal memory is sets on Auto, for you to check that first...
-Press menu button and look for setup then press Ok button
-Under setup look for IMAGE STORAGE it should be on auto if its Internal memory you need to select the image storage press ok button the select Auto then press Ok button again.
-make sure the Memory card that you are using is just 1GB or 2GB SD card only do not go over than that because it will not be compatible on the camera C875
GudluCK!
Posted on Nov 03, 2009
leepania
  • 1099 Answers
SOURCE: Kodak C875 and the flash does nto work
Yes.
If OoW. the repair pice is: 48,44 pounds.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 16, 2009
  • 11967 Answers
SOURCE: zoom lens stuck in out position, kodak C875 camera
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 28, 2010
  • 262 Answers
SOURCE: I can't seem to format
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Posted on Feb 19, 2011
The Camera will randomly turn itself off, batterie...
its better use Kodak battery for you Kodak camera.FYI there's a lot of brand of AA battery like energizer,duracel and also kodak.if you compare the size or the height of all battery its totally different.especially the kodak are more taller than the other.thats why if you use other brand it works only 5 shots only or less.
May 21, 2010 | Kodak EasyShare C875 Digital Camera
Brand new AA batteries last only a few minutes, i.e. 5 new pictures. why?
Are you using normal AA batteries? i.e. non-rechargeable ones? If so, this is probably why... Digital cameras will **** these dry super fast. You will need to use some AA Nickel Metal Hydride rechargeable batteries (NiMH) with at least 2500mAh capacity to get some decent run time.
Apr 01, 2010 | Kodak EasyShare C875 Digital Camera
My C875 Kodak Camera will not read the memory card, but it will read the internal memory
GudluCK!
Nov 03, 2009 | Kodak EasyShare C875 Digital Camera
What kind of rechargeable batteries do I get for my camera? Kodax Easyshare C875
You can get any type of AA rechargable batteries. Doesn't matter what brand as long as there are AA. You can get a charger/battery kit from amazon.com or newegg.com
Oct 23, 2009 | Kodak EasyShare C875 Digital Camera
Kodak easyshare z650, turn it on it gives you enougn time to take one picture then shuts off. put new batteries in twice still the same.
What sort of batteries are you using??
I've got the same camera and it works best with Lithium AA batteries if you not using the bigger one.
Normal AA batteries won't work.
Jul 12, 2009 | Canon Cameras
Jan 18, 2009 | Kodak EasyShare C875 Digital Camera
Downloads
To copy from internal memory to memory card, follow the instructions on this page of the user guide.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 17, 2009 | Kodak EasyShare C875 Digital Camera
Kodak Easyshare
Remove the batterty andclean the internal battery contact with an
eraser on the end of a pencil- take a flash light to look inside the compartment to enfure they are bright and clean.
Make sure the battery door and contact srip are a good tight fit
Hold the door down with a finger whilst switching on
Other than that there is little moreyou can do
Jun 28, 2008 | Kodak EasyShare Z740 Digital Camera
Kodak easyshare C875
Sounds like the same problem as with the samsung digimax 401... Internal memory. Insert a memory stick and hopefully the camera will come back to life,no?
Oct 31, 2007 | Kodak EasyShare C875 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
211 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
