My washing machine is not letting me do anything because the controls are locked. how can i reset it or unlock it?
  • 15,935 Answers
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks!!
Posted on Nov 10, 2010
Maytag dryer control is locked. how do I unlock it?
Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light goes out when the control panel is unlocked. Also try unplugging it for five minutes to allow it to reset
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
Jan 12, 2018 | Maytag Washing Machines
My washer has a red lock displayed on the screen and it won't do anything.
the control lock function is activated...hold the options and select buttons together for 15-20 seconds(won't take this long) and it should unlock your controls...any problems, let me know
Bruce Denton
Jan 23, 2011 | GE WSXH208A Front Load Washer
The panel says control locked and the machine will not do anything
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control and to eliminate the possibility of an electronic glitch if pressing and holding the End of Cycle button does not work. Replace the control if unplugging and the pressing the End of Cycle button fails to unlock it.
Jan 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked light on will not do anything else
The control can be unlocked by pressing and holding the End of Cycle button for 3 seconds or until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control and make sure and eliminate the possibility of an electronic glitch if the End of Cycle button does not unlock it. Replace the control if unplugging and the End of Cycle button fail to unlock it. Indicate the exact model number of the machine for the right replacement part number and for specific replacement procedure should you require it.
Aug 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the DRAIN/SPIN button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Kenmore Elite 45986 Front Load Washer
Washer lock
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance. This can usually be reset and usually is not an indication of an actual problem with the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Jun 07, 2010 | Maytag EPIC MFW9700S Front Load Washer
Control locked
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. You also cannot unplug the washer to reset it. The Control Lock can inadvertently be set following a power outage, or by leaning against the control panel and is usually not an indication of a washer malfunction.
If this is a Whirlpool Duet series, the following link explains how to lock/unlock this feature:
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope you find this information helpful.
Apr 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked. How do I unlock it?
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off to unlock the control. The End of Cycle button is located at the extreme right of the console. Unplug the machine for at least 15 minutes to reset the central control unit if the control cannot be unlocked using the End of Cycle button. Let us know if the control cannot be unlocked even after the machine is unplugged.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
"Controls Locked" light lit, unlock button has no effect
Have you tried unplugging the machine for awhile to let the board reset?
Nov 14, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Flashing Control lock light
Press 'options' & 'select' for 5 to 6 seconds, controls may unlock (depending on your model) If it is a key you see, it is the child lock.
Apr 29, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
