Question about Night Owl Optics Cyclops Compact NOCC3 Monocular
It turns on but when you look thru the lens it is black. You don't see anything.
    Master:
  • 577 Answers
Hello, These Russian manufactured night vision devises are cheap. The image intensifier tube has gone south, it finny,flip out, dead. Because these night vision defisve are sold by many different US companies they don't have parts for them. You buy it, and when goes, you throw it away. Sent to me for recycling, there really not much to recycle. Sorry, GB...stewbison
Posted on Sep 28, 2011
I have the same problem this guy had: I have a Sony Cybershot 8.1 megapixels. Every once in a while the screen will turn black when I turn the camera on. The display will come up (shaky hand, flash, etc.)...
The camera either has a stuck aperture inside the lens or a bad CCD sensor.
The aperture is the opening that allows light to enter the lens. If it's stuck closed no light goes in, so no display on the LCD and solid black pictures. The way to fix it is to replace the lens. You can try tapping or banging the camera on it's side on your hand or even gently on a table. This might unstick the aperture for a short time, but it will just stick again later.
If the CCD is bad the sensor won't show anything other than solid black, or sometimes purple/pink smeared lines. Again the solution is to replace the lens assembly, or look for a used CCD online and just switch that out instead.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 12, 2011 | Sony Cyber-shot DSC-W100 Digital Camera
I get a black screen thru my viewfinder and screen - not able to see anything to take a picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jan 30, 2011 | Canon PowerShot S2 IS Digital Camera
Camera will not take pictures and I can not see anything thru
Found this on another web site. Worked for me
Turn the camera on in shooting mode.
Turn the mode selector to shutter priority (“Tv”).
Use the four-way button on the back to set the shutter speed to 15 seconds.
Press the shutter release. Count to seven, then pop open the battery compartment. (I discovered that the camera will beep when you do this.)
Wait several seconds, then close the battery compartment.
You may need to repeat the above sequence several times to unstick the iris. If that does not accomplish it, you will likely have to send the camera in for repair.
May 13, 2010 | Canon PowerShot S2 IS Digital Camera
The screen is black & you can't see anything thru the view finder, and yes the lens cap is off.
They had this problem before and there was a class action suit. Looks like history repeated itself!
http://www.samsungclassaction.com/7.html
Jul 09, 2009 | Samsung SC-D23 Mini DV Digital Camcorder
Can't see anything on screen or thru viewfinder
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 08, 2009 | Canon PowerShot S2 IS Digital Camera
Lens & screen show black instead of item to be shot.
You need to go into the menu function to turn the screen on (this feature saves the batterys)
Dec 08, 2008 | Cameras
Canon S2 IS
Your camera has the know issue of Stuck shutter, whichhappens after some time (weeks or months) thata camera is notused.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires th skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S2".
Best regards,
Jun 17, 2008 | Canon PowerShot S2 IS Digital Camera
Black will not print
Hi springfield, From what you describe I don?t think it has anything to do with your printer drivers. I would try the following: -Run a couple of nozzle cleaning jobs. -If no change I would suspect a defective cartridge and would try a brand new HP cartridge. If these don?t work I?ll need some more details such as do you refill cartridges, buy remanufactured cartridges or use new HP. Also is this still under manufacturer?s warranty? I don?t want to suggest anything that would void it. Let us know what happens and please don?t forget to rate the posting.
Jan 23, 2007 | HP LaserJet 3300mfp All-In-One Printer
LCD showing "remove len cap and press reset button" always
Simple! Read warnings carefully! It said "remove lens cap and press SET button"! So remove the lens cap and then press the SET button (or arrow downward in the four directions button)! You don´t need to RESET anything...
Jan 15, 2007 | Panasonic Lumix DMC-FZ1 Digital Camera
Night Owl Optics Cyclops Compact NOCC3 Monocular Logo
412 people viewed this question
Top Night Owl Optics Optics Experts
wadingriver
wadingriver
ray gallant
Are you a Night Owl Optics Optic Expert? Answer questions, earn points and help others
