Question about Carrier BCA101R Air Conditioner
Help me out
Where do i find blades and shutter???
  • laurie barnes Jun 16, 2008
    IS THEIR ANY ONE TO HELP ME FIND BLADE AND SHUTTER?????.
  • 4,889 Answers
Here is the contact info.. You can contact them and place an order..
http://www.corp.carrier.com/www/v/index.jsp?vgnextoid=76a61d6b31c08010VgnVCM100000cb890b80RCRD
Posted on Jun 16, 2008
Shutter won't open and it beeps can not get it to stay on
dirt in shutter is likely. Make sure the battery is fully charged before you try this. The added power may help overcome the sticking. You can help the shutter open with a toothpick by adding just a little force to one of the shutter blades. if you can excercise the shutter this way a few times you might free the shutter mechanism up. You will have to disconnect the battery after each try as this will reset the circuitry.
Jun 06, 2014 | Samsung SL35 Digital Camera
How to I shut off the shutter noise on my Canon Rebel 2ti?
You can't. When you take a picture, the mirror flips up, the shutter blades open, the shutter blades close, and the mirror flips down. All of those are mechanical operations that produces some noise.
Aug 22, 2013 | Cameras
Frozen shutter
The usual cause of this is a failure of the motor in the SQ unit that drives the mirror up and down, operates the aperture lever, and charges the shutter. This parts is so notoriously bad that it is on permanent back order at Nikon
Some of the other solutions with popped shutter blades - usually when I see this it is caused by the customer trying to clean his image sensor and having the shutter blades close on his/her tool.
Jan 17, 2012 | Nikon D40x Digital Camera
Zenzanon 80
The lens does not have a shutter - that's in the camera body. The lens contains the aperture or f stop adjustment. It is done by injecting or retracting blades in the light stream of the lens barrel between the front and rear optics. Check the aperture blades to see if they move easily and open equally by varying the f-stop ring on the lens while looking through it. If not moving all the blades the same amount or it does not continue to restrict the opening as you increase the f-stop value, there's something wrong with the lens.
Are you sure you haven't accidentally activated any exposure compensation adjustment on the camera body?
Jan 10, 2012 | Bronica 80mm f/2.8 Zenzanon-PS Lens
I have a nikon fm10..when changed my lens to 50mm f1:1.8D, i would press the shutter release button, then the shutter will close,just close! i know it suppose to close and open rapidly, (my shutter speed...
Does this fault happen only with that lens? Also, you're wrong about the shutter: it appears you're mistaking the shutter assembly for the lens diaphragm (also known as the "iris").
Older lenses often have sticky diaphragms, usually due to oil migrating onto the individual blades and sticking them together. A sticking diaphragm can interfere with the shutter operation on some SLR's.
Fixing a sticky iris is usually a professional job, but if you're careful then with a simple non-autofocus lens like yours it's often possible to do on a DIY basis but will be very fiddly. The object is to get to the iris blades and to then thoroughly clean them. They're Teflon coated so should slide over each other without lubrication, but their pivots normally need the tiniest bit of lubrication. If you try and fail then you've lost nothing as the lens was effectively scrap anyway and there are plenty of cheap/free replacements around.
Sep 10, 2010 | Nikon FM10 35mm SLR Camera
What is the methode of cleaning a ccd (doing the dirst free) 35 mm slr camera (Nikon D70s)
keep the camera to m mode and keep shutter speed b and hold click and take hear-bud take care of shutter blade or your will damaz shutter blade
Sep 08, 2009 | Nikon D70s Digital Camera
Air conditionder
you can replace the blades but they come as a set. you cant get a single blade. As for the shutter you just have to get it replaced.. I can help you find the spares online if you like..
Jun 16, 2008 | Carrier BCA101R Air Conditioner
I have broken my HP Photosmart R817
I just fixed mine and what came out of the end of the lense housing was the shutter assembly. Your camera will still work but the shutter will not operate for protecting your lense.
What was on the ground from the shutter assembly looked like six parts but actually there's eight:
1 - Front round plate (what you see if shutter assembly was still in the lense housing).
2 - Hair size springs that hopefully stayed in the sides of the front round plate. IF NOT OR EITHER ARE LOST, THE SHUTTERS CAN'T BE SET TO CLOSE SO SKIP THE STEPS BELOW ABOUT INSTALLING THE BLADES.
1 - back round plate (black with four tabs).
2 - Larger L-shaped blades.
2 - Smaller L-shaped blades.
Place the front round plate with cosmetic (engraved 'PENTAX...) side down and look at the inside for two round mounting posts on the left and right. You will be using the larger of the two posts on each side for placing the L-shaped blades.
Place the larger L-shape blades with the hole end onto the posts. Blades should swing freely and their backs match with the shape of the inside of the front plate when open.
Place the smaller L-shape blades on top of their respective larger L-shape blades with the hole end onto the same posts used in the last step. Blades should swing freely and their backs match with the shape of the inside of the front plate when open along with the larger L-shape blades.
Springs (long ends) will need to notch into the smaller L-shape piece end (nearest the hole/post end). This is a real trickly part of the assembly and I used two tools like large pins or needles to pry the spring into the notch. If you can't do this, no sense in even leaving the four L-shaped blades inside of the front round plate since the shutter will not close properly without the springs.
Align and snap the back round plate tabs onto the front round plate. The shutter assembly is now ready to put back into the lense assembly.
MAKE SURE THE CAMERA IS IN THE OFF POSITION AND THE LENSE ASSEMBLY IS RETRACTED!
Align the front of the shutter assembly with the engraved wording properly oriented (not sideways, not upside down, etc.) and press gently into the lense assembly until completely in the end of the housing.
If blades were installed properly, they will open when the camera is turned on, and close when the camera is turned off.
If blades were not installed, the empty shutter assembly (back round plate snapped onto front round plate) can still be pressed into the lense housing...the shutter will just not work and the lense will always be exposed. Actually, this is one helluva lot easier than fixing the shutter assembly and not the end of the world for your camera's operation!
Mar 23, 2008 | HP Photosmart R817 Digital Camera
Re: Shutter Wont click
Hi , check everything set c amera speed to 60/seconds auto or manual / check also the the camera shutter blade , open the lense and close to activate the shutter blade .
Feb 17, 2008 | Nikon F80 35mm SLR Camera
Bad picture developing
Since this happened on two seperate rolls of film, the problem may be that the shutter blades have been bent out of place.  This can cause the symptoms you describe.  Have a qualified technician look at the shutter.  Usually the blades can be reset.  In bad cases the blades may be bent or creased. If this is the case, the shutter may need to be replaced.
Oct 23, 2007 | Nikon N55 35mm SLR Camera
Carrier BCA101R Air Conditioner Logo
139 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
