The water in my bath tub is not getting hot as the wash basin or kitchen, what can I do, would flushing the hot water heater help?
  • 2,299 Answers
No. Flushing the water heater will not help. You can do two things to get hotter water in the bath tub. You can turn the water heater up 5-10 degrees. Or insulate the hot water line in the basement or in the crawl space under the house. Turning the water heater up will make the water hotter everywhere. But you can adjust it at the kitchen and wash basin.
Posted on Nov 09, 2010
How to clean a whirlpool bath tub
There are three main things to tackle when cleaning a hot tub or whirlpool bath. Those things are:
1. Bacteria
2. Grease
3. Grime and dirt
To address all three of these issues you'll likely need separate products. There are liquid versions of the degreaser and cleaner, and there are tablet versions for sanitizing.
Simply fill up the whirlpool bath with warm water, put the cleaning liquid in the cleaning outlet (or if you don't have this, just pour it into the bath). Put the tablet in the bath and then just run it.
This should do the job.
Pure Spa Whirlpool Bath Spa and Hot Tub Cleaning Kit
Nov 17, 2015 | Jacuzzi Whirlpool Cetra Whirpool Drop-In...
I'm runnin out of hot water in minutes.Baseboard is fine.The hot water pipe off the boiler is hot and it goes thru a dial or adjuster to the taps.And it's warm/cold after that dial. Where do I start?
that adjuster is there to reduce the water temperature so that scalding from boiling water doesn't occur
they can be adjust but if this problem has come in after a period of time then the sensor wax inside the adjuster is not as it should be.
they do fail and need replacing
most plumbers put the unit on the hot water outlet because they are lazy as the standard says that it is primarily for use on the shower, bath, basin systems and wash machines and kitchen sink are not required to be temp controlled.
Apr 20, 2015 | Water Water Heaters
The hot water temperature is not constant with the burner shutting off
You can get a sound like that when there is too much sediment in the bottom of the tank. Turn it off drain and flush it until the water runs clean.
Aug 21, 2014 | Water Heaters
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
Jacizzi tub and water is not hot enough
When filling the tub if there is not enough hot water to fill the tub you will probably need a bigger water heater.
You can add a Bath Heater to your tub if the water is cooling down too quickly while you are using it however, a Bath Heater will NOT heat the water. They will only maintain the water temperature you start with.
Rod
US Parts Center
888-521-6183
Jan 08, 2013 | Home
Temperature with my on demand water heater is inconsistent
have a plumber check the installation as it appears that there is a temp control mixer in the kitchen line that should be in the bathroom line
Many states and countries now have made it mandatory the full uncontrolled hot water cannot be used in a bath, shower, wash basin but has to limited to a max temp of 70 C to prevent burns to the skin
May 29, 2017 | Bosch & Tankless LP Hot Water Heater
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Bathtub water does not get hot enough-
take off handle and you should see a nylon ring with teeth just take off and put back in the oppisite direction that you removed it its there to prevent kids from getting burnt
Feb 27, 2009 | Plumbing
Blockage Maintenance
# Regularly remove any hairs that get trapped in the waste plug hole. # Keep small objects such as combs, medicine bottles and toilet rolls away from places where they could accidentally fall into the toilet. # Regularly flush the wash basin and bath or shower pipe work with hot water and a disinfectant to clear soap residue and prevent build up over time. # Don’t flush away large and disposable items such as sanitary towels, nappies or product wrapping as they can become caught in the drainage pipe. # Do not dispose of waste food scraps and cuttings down the kitchen sink. These are much better composted. If any items do fall into the sink pull the vegetable material out of the plug hole, do not try to poke through as you could impact the blockage making it harder to remove. # Never dispose of cooking fats down the drain system. As they hit cold water they will solidify. If there is absolutely no alternative you should dilute and emulsify the fats by mixing them with hot water and of detergent. Keep the water running for a minute after you have done this to keep a clear water flow. # For complete peace of mind, particularly if you are running a business you can request a regular drain surveys and get your drainage system checked regularly by a CCTV drain inspection service. This will give early warning of any potential blockages and also enables you to keep an eye on the structural condition of the drainage pipe work.
Aug 27, 2008 | Kohler Model 7202: Drain For Purist® Baths...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
