How to reset the bios system in compaq computer.
  • 2,386 Answers
I dont know which compaq system you had, but generally there are two ways to reset bios
1. short the bios reset jumper near battery on motherboard for a while and place it back, it will reset the bios. 2. take out the battery from motherboard for some time and put it back to motherboard it will also reset the bios
if there is no password problem then just load bios default from the bios menu.
Posted on Nov 09, 2010
  • 340 Answers
Reboot the computer and hit f2 when you see the logo come up and this will take you into the bios setup. Arrow over the the tab that says exit and arrow down to the selection that says load setup defaults and exit. This will reset the BIOS to the factory defaults.
Unable to log in
Which operating system ?
The Compaq Presario CMOS password is an administrative security measure built into the firmware of a Compaq computer.
This password is stored in the motherboard's BIOS (Basic Input Output System) and provides for hardware-level security.
This password may be accidentally set or forgotten over time and must be reset in order to boot the computing system.
Disconnect the Compaq computer from any electrical sources and remove the side access panel from its case.
This may require the removal of one or more thumbscrews on the rear of the computer case.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Locate the CMOS battery.
This battery is a round button-type battery located in the bottom-right corner of the Compaq Presario motherboard.
Grip the battery by its edges and pull it straight away from the motherboard to remove it.
Press and hold the power button on the case for ten seconds to remove any remaining electrical current from the computer.
This removes the CMOS settings and returns it to the default state of having no password set.
Replace the CMOS battery.
Replace the computer's side access panel and re-establish any previously severed electrical connections.
http://www.youtube.com/watch?v=zjGHpJqVJkM
Replace a CMOS battery inside a desktop computer
http://www.dewassoc.com/support/bios/bios_password.htm
http://www.tips4pc.com/articles/Computer Troubleshooting/Remove the CMOS battery to reset the bios password.htm
Jan 14, 2014 | HP Compaq Presario SR5450F (KJ383AA) PC...
Compaq 6510b reset cmos/bios password
try this: Make sure the battery for the notebook is out in step 8
the procedure to reset the CMOS/BIOS is in the maintenance and service guide on page 46.
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the
computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery (see Battery on page 48).
5. Remove the real-time clock (RTC) battery (see RTC battery on page 68).
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Jul 27, 2012 | HP Compaq 6530b Notebook
I forgot my BIOS password and i can't access it becos i don't know the password.
HP Spare Key can be used to reset BIOS password. It is provided by HP Corporation. So when you forgot BIOS password on HP computer, just download it and get perfect BIOS password reset.
How to reset HP bios password with Spare Key or other ways?
Please refer to reset HP Elitebook password. In this passage, you also can learn how to reset Windows administrator password easily.
http://www.isunshare.com/windows-7-password/reset-hp-elitebook-password.html
Jun 12, 2011 | HP Compaq 6730s Notebook
Compaq Monitor WF 1907 immediately after the Desktop /Monitor (set at VGA) is turned-on gets stuck at the COMPAQ sign in the center and F10=SetUP, EXC=Boot Boot Menuplus F11=System Recovery all displayed...
Try using your windows cd to boot up the computer and if that does not work then you may need to reset the bios. Inside the case if it is desktop there is a way to reset the the bios. There is a jumper that needs to be switch then switched back that will reset the bios. If this does not work may need to get a new hard drive. The MBR ( Master Boot Record) may have been corrupted.
Mar 26, 2011 | Compaq Presario SR5712F PC Desktop
I need reset bios password Notebook HP Compaq 2710p
I know some methods to reset bios password.
1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes.
2. Follow some hard tutorials, it is difficult to do. It is better that you are a expert. For example this tutorial: reset BIOS Password?
So I would suggest you the 1st method. Hope it helps.
Aug 30, 2010 | Compaq 2710p Tablet PC
How do you reset the power on password on a Compaq 6720s laptop
Hi There,
If you're trying to describe the BIOS password, then this link is the best information website on the subject I've ever run across. Best of luck....
http://www.tech-faq.com/reset-bios-password.html
Aug 04, 2010 | Compaq Presario Notebook
The COMPAQ splash screen displays, with F1-Setup and F10 system recovery option, but then displays 'DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER'. This is my sisters computer, and she says there...
You may be able to purchase a system disk from Compaq, otherwise, try any generic XP disk. It won't have any Compaq drivers, but at least you can reformat the C: drive and get XP on it.
Nov 27, 2009 | Compaq Presario S6300NX PC Desktop
Bios password screen popped up, will not reset
Taking out the bios battery does not reset the system. how do i reset the system
Dec 04, 2008 | HP Compaq Business nx6125 Notebook
How to reset my compaq computer back to the factory setting
Reset your operating system software (Windows XP..)to Compaq factory setting : restarting your computer. Hold down F10 key, your computer will go into recovery software provided windows recovery was preloaded into your hard disk during installation.
Follow on screen instruction.
If it your Bios you want to restore to factory setting, restarting your computer hold F1 key, entering BIOS set up. Look and press the key assigned "Default Loading" save change and exit Bios set up.
Does that solve your curiosity
Jul 27, 2008 | Computers & Internet
Computers & Internet Logo
2,224 people viewed this question
David Payne
David Payne
