Question about AT&T Lucent MLS-12D Phone
We have an AT&T Avaya Partner II phone system. How do we extend the number of rings before the voice mail picks up?
  • george  peters
    george peters Nov 09, 2010
    Are you talking about the main greeting or on an individual mailbox?
  • sales299 Nov 09, 2010
    This is for main inbound calls. The Partner mail vs picks up only after 3 rings. We tried the vms cover rings using code 117, but the system does not accept this with the MLS-12D.
    Thanks
    President:
  • AT&T Master
  • 860 Answers
Unfortunately on the earlier Partner systems they only gave you the option of either 2 rings (immediate) or 4 rings (delayed) . The program number to look at the setting on yours is # 506.
Posted on Nov 09, 2010
Voicemail will not pick up
the voice mail system must be installed
need to add a voice mail to a spirit
check this: http://downloads.avaya.com/css/P8/documents/100011344
Jul 04, 2014 | Avaya Lucent Partner 616 Phone
I have the Avaya partner voice messaging and the mailboxes have been set up but when the phone rings twice it goes to fax not voice messaging. How can I fix this
Your voice mail extensions are programmed incorrectly in the system. You need to enter the System Programming mode from Ext 10 or 11 and use #607 to set the correct voicemail extensions.
Aug 28, 2013 | Avaya Corded Phone avaparp18d
Voice Mail Pick up
Changing the vms hunt delay on a Partner ACS system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#505"
the display should say VMS Hunt Delay and mode:
enter 1 for day mode or 2 for night mode
enter line you want to program in 2 digit format (line 1 =01)
enter number of rings (2)
press feature "00" to logout
May 02, 2013 | Avaya Lucent / Partner 206ec Expansion...
Incoming calls ring once and are told thew will be transferred and then a voice tells them goodbye
Sounds like your system lost its programming so now the voicemail ports are just like extensions, they are ringing and picking up. And since the voicemail doesn't know where the phone systemn is, it just transfers all calls to the lowest numbered extension (10)
The system needs to be reprogrammed completely.
Jan 10, 2011 | Avaya/Partner 4-Line Display PBX...
My Avaya phone on our Avaya system only rings
ask your local admin to remove your phone from coverage path
Apr 15, 2010 | Linksys SPA941 IP Phone
Voice Mail Problems
You will want to go into the night attendant and check the selector codes. What voicemail do you have?
When you dial into voicemail, oicemail Vicky answers and says, "welcome to ....." what is the rest?
Jul 22, 2009 | Avaya Lucent Partner 616 Phone
Auto attendant does not pick
What kind of phone system? If Partner, it sounds alot like you lost all your programming, so the phone system isnt programmed to know where the voicemail is. So hwen a call comes in, the ports where the voicemail is, ring, so they pick up, but dont know what they are to do with the call, so they shove it to the receptionist.
#505 needs to be programmed, then #206, that will get you to at least asnwer incoming calls.
Need to know more, like WHAT KIND OF SYSTEM.
May 27, 2009 | Avaya AT&T Partner Phone
Installing partner mail vs r4.1
check the voice mail ports. Can you dial them and have them answer?
Also check that each extension is programmed to hunt to voice mail in the partner programming
Jan 05, 2009 | Avaya AT&T Partner Phone
Call Waiting
THere are two answers to you question, depending on certain options and conditions.
First, where is the voice mail and where is the call waiting coming from?
1. If Voice Mail (VM) is located in the central office and you have a destination for call forward BUSY/NO ANSWER it will go to CO VM.
2. If Voice Mail on premise (Partner Mail), and you have CF BUSY/NO ANSWER set on your phone, it will go to voice mail....IF the call waiting is coming from another line. The CF and ring count is set in Partner system programming.
3. If you have call waiting coming on the same phone line and don't have CO VM, then you have no voice mail.
My CO codes for VM are 72# for Call Forwarding and *92 for CF Busy.
As Always, YMMV
Carl
Sep 14, 2008 | Avaya Partner 34B Corded Phone
VOICEMAIL
This is all programmed in the phone system settings. Your phone can be used on different Avaya phone systems (AT&T, Lucent is Avaya now) and you can also have different voice mail systems. They all program differently.
Sounds like your phone port is not programmed to use voice mail. You can have your phone port programmed to do many different things if nobody answers. Mostly you have the call transfered to another station after so many rings. That other station (extension) could be the operator, a calling group, a voice mail box, etc... Some systems allow you to change the number of rings on a per-phone basis, others only have one no-answer timer for all calls.
You can get all the manuals from www.avaya.com for free but you need to know which system and version you have first. Programming can get very complicated and you may find it easier to hire a local phone installation company that is familiar with your system to do the changes for you.
Jan 28, 2008 | Lucent Legend MLX-28D Corded Phone
AT&T Lucent MLS-12D Phone Logo
216 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
