Getting cooler air
Greetings, I've tried everything in the manuel to get my air conditoner to a "cool" 62 degrees all over my house, but it just doesn't seem to want to do that!! The cool setting is set at 76 & the Heat setting is set at 68. Is this the correct setting to get 62 all over the house. We have central air conditoning (Payn air conditioner) is the name brand I see on the air conditoner. Filter's are clean inside as well as outside. {{{Help please!!!!!!!!!}}} Hubby had a stroke & its so hot here about 100 degrees today>Vacaville, CA
Thanks in advance for your assistance,
Ksweet2015@Comcast.net
  • Ksweet2015 Jun 23, 2008
    Thanks! Your advice solved my problem..... :o) My "Brand New" Trane air conditioner is work perfectly. I had the installer to set it
    at the temperture you suggested & now we're completely comfortable at that setting. Thanks again Fix Ya! You're the greatest online fix it I know!!!!!!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 114 Answers
If you are desiring to have it 62 degrees in the house, the cool setting needs to be more to like 66 deg and the heat setting needs to be like 58 degrees. that would make it more around 62 degrees in the house.
change the heat setting first to 58 and then change the cool setting to 66. this gives your temperature 62 +/- 4 deg.
Posted on Jun 21, 2008
Breeze air wkl 3000 blinking temperature al
NEW UNITS HAVE A VISUAL ALARM PRE SET TO KICK ON AT 62 DEGREES OR ABOVE, WHE THE WINE COOLING UNIT READS 62 OR ABOVE IT WILL FLASH "AL" AND THE TEMPERATURE NUMBER THAT FORVED IT TO KICK ON, IT IS JUST A VISUAL ALARM IT WILL NOT TURN UNIT OFF OR STOP IT .
THIS FEATURE WILL SHUT OFF ONCE THE UNIT READS ANY TEMPERATURE BELOW 62 DEGREES.
Dec 27, 2013 | Breezaire WKL-2200 Wine Cellar Cooling...
Coleman thermoelectric cooler not cooling
Sounds like the Peltier effect elements have failed.
http://www.tetech.com/Peltier-Thermoelectric-Cooler-Modules.html
Depending on your handyman skills, you can change them yourself or have someone troubleshoot and change them.
Sep 12, 2012 | Coleman 40 Quart Powerchill...
What is the best temperature for white wine to be in?
It is important to keep the wine cool and in stable temperature that doesn't fluctuate very often. Bright tart white wine: 48-52 degrees; sparkling wine: 50-55 degrees and rich white wines: 58-62 degrees.
May 29, 2012 | Furniture
I have never used central ac before - how do I set it? If it is on 75 will that cool the house? If I want it cooler, do I put it lower? like 65?
As to your question 'will 75 cool the house?' The answer is 'yes' - if the outside temperature is low enough. Typically speaking you can expect your central AC to cool a properly insulated house to a down to a temperature of about 20-25 degrees lower than the outside temperature. For example - if the outside temp is 95 degrees. You could expect to get your house down to 70-75 degrees. If the outside temp is 110 degrees then you could only expect to get the house to 85 or 90 degrees.
So .. as you can see - your 'inside' temp will be directly affected by the 'outside' temperature.
As to the operation of central air; it is very simple.
I would suggest that you not pay 'too much attention' to what you have the thermostat set on. A comfortable temperature - is a personal thing - so - I would set it somewhere - say 72 and see how I (and others in the house) was handling that setting.
If you want it 'cooler' just 'notch' it down a degree or two - if you need it a little warmer - turn it up a degree or two. Do this "fine adjusting" till you have the temperature setting you are comfortable with.
Usually the more you can leave your thermostat alone the better off you will be from a comfort position and an electrical useage standpoint. Obviously, the higher you have your thermostat set the 'less' it will cost you on your electric bill.
How high you set the temperature is a balance you have to come to based on how comfortable you want to be - matched with how much you want to hold down the electric bill.
hope this helps
Aug 14, 2010 | Honeywell Heating & Cooling
I have problem about over heating of my p4 procesor specialy in summers, my motherboard is 775i65G ... in summers the temp. of processor reaches 62 degrees and cpu fan runs on high rpm which results in...
all fans in time will get louder. The power supply unit has a fan and if you don't already have a fan on the CPU then you can add one to help cool it The fan in the power supply can be upgraded to a quieter one if need be. Any dust on in the case on on the circuit board will retain heat so getting some dry air and cleaning them should be performed. Be sure to ground yourself to the medal case when working with the case open.
May 11, 2010 | Asrock 775i65G Motherboard
Rheem air conditoner problems
it might have leak and low on gas or the main PCB board is defective. try switching off and on circuit breaker ti might reset the system
May 28, 2009 | Heating & Cooling
Computers & Internet Logo
216 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
