Question about Hotpoint RLA31 Compact Refrigerator
We have a hotpoint RLA 34 ( MICROBAN ) FRIDGE . water keeps seeping into the bottom , under the crisper box tried turnining temp down , made sure it's level , no blocked drainage hole . door shuts tight . Any idea what's causing this .
  • 316 Answers
You said no blocked drainage hole, where was the drainage hole that you checked located? Did you pour water down this drain, and furthermore did you check that the water you poured into the drain flowed into the condensate pan on the outside of the fridge? Unless you have a problem with an ice maker leaking water, it sounds very much like you do have a blocked drainage hole, otherwise known as a defrost drain. the drain system begins underneath the evaporator coil inside the freezer, this is where the water that is collected in the defrost cycle flows into a drain tube that leads the water down to the condensate pan. The best and safest way to clear out this drain is to blow it out with compressed air, after you remove any and all ice at the beginning of the drainage system, in other words, the hole located underneath the evaporator coil.
Posted on Nov 09, 2010
  • jimg001 Jun 27, 2011
    I have a related problem to above. My 4yr old RLA34 fridge did not have a condensate pan and has been leaking onto the compressor pot and onto the floor all this time. I only noticed when I replaced the floor last week. I now have the 'stick on' condensate pan from Hotpoint but with no instructions on fitting. Hotpoint service people could not tell me where the pan gets attached to. Can someone help please - does this condesate pan get glued to the compressor pot? Does anyone have a diagram of the fridge that shows where the condensate pan is meant to be stuck to? Thanks
We just bought a GE gbe21dgkarww we are having trouble wth the crisper, they are freezing my fruit and vegetables. Temp. Cool on freezer on coldest
Fridge temps are actually cooled by the freezer,try turning freezer temp down somewhat-and I highly recommend buying a fridge thermometer,generally speaking I try to keep my fridge at about 34-35 degrees,you can go SLIGHTLY higher,is fridge section directly over freezer??
May 09, 2017 | GE Refrigerators
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
There is water collecting continuously at the bottom of my fridge under the crispers. Do you know how I can fix?
Most frost free refrigerators take water from the freezer so you do not have to defrost the freezer. That being said there should be a drain under the crisper. Check to see if it is clogged.
you may need to put something under the refrigerator to collect the water..
Jan 03, 2015 | Refrigerators
Water in bottom left crisper drawer and under drawer
I'm sorry to say that it sound as though your door gasket may no longer be sealing correctly.
For me, it's simply a task of getting a replacement gasket for that make and model.
To remove the old one you would, simply, peel the inside of the gasket toward the outside of the edge of the door revealing the mounting screws. Remove these screws all the way around and replace with the new one in the same fashion...
The reason that I recommend this is that humid air outside of the refrigerator can seep past a worn gasket and condense on the inside surfaces making its way to the bottom and into those drawers.
Feb 16, 2014 | Whirlpool Refrigerators
Water comes off somewhere in the bottom of my fridge. what could have caused it?
When your refrig goes into defrost , the water runs down the back of the refrig ( inside ) and out to the drip pan thru a drain hole under the crispers . If water is under the crispers , remove the crispers and you should see a " cap " covering the drain hole . Sometimes crud will cover the slots where the water is supposed to drain , causing water to pool under the crispers . Just remove this cap , clean , and reinstall .
Mar 20, 2011 | Magic Chef Refrigerators
Frigidare 1812 frig-water under crisper drawers
clogged drain line somewhere in fridge plumbing
Feb 21, 2010 | Refrigerators
Bottom of fridge collects water
Hello there:
I have written a few steps for you to follow and try ok?
  1. Manufacturers have different ways to dispose of the water created during automatic defrost cycles. The most common design routes the water down a rubber tube on the back of the fridge to a tray beneath. This tube often gets plugged with breadcrumbs, peas etc. and can generally easily be removed and cleaned.
  2. Make sure the end of the hose is sitting in the defrost tray.
  3. If your hose was not plugged and you have found water running down the back wall inside the fridge or a pool under the bottom crisper has formed. Check if there is a small funnel located on the back wall near the top inside the fridge. It can also get plugged; you can use a small wire and work it in and out of the hole.
  4. Some designs do run the water down the back wall and have a drain hole under the crisper, make sure it is not plugged.
I hope that this has been verry helpfull for you
best regards michael
Nov 06, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 13, 2009 | Refrigerators
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Hotpoint RLA31 Compact Refrigerator Logo
857 people viewed this question
Top Hotpoint Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
