Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Water leaking inside
Kenmore Refrigerator; top freezer; no ice maker.
Water is puddling on the first (highest) shelf. From what I read
maybe the drain to the water pan is plugged.
1. Where do I access the drain pipe and what is the best
way to unplug it.
Thank-you.
  • omalito_1981 Sep 05, 2008
    kenmore my refrigerator has a water leak that may be below
Unforturnately, I have the same problem. You have to take the bottom panel of you freezer off. You will have ice built up. You will have to remove the ice. In the back, there is a hole that drains to the drip pan, that has become frozen solid. I have this problem about every 30 days. I wish I knew how to fix the problem. My dad has the same refigerator freezer, it's a problem for him too.
Posted on Jun 22, 2008
Water is leaking inside of the refrigerator on the (if you are looking into the fridge) the left side. I cannot tell where it is coming from - i see no dripping from anywhere but it sits in puddles on the...
I have a Whirlpool Top-mount refrigerator. Whirlpool also manufactures many of the Kenmore refrigerators.
A few weeks ago I noticed a puddle of water on the top right shelf in the refrigerator section. I figured out that it must be the water that forms during the defrost cycle and normally drains down through a tube in the back into an evaporator tray beneath the refrigerator. Something was preventing the water from draining away and instead it was dripping through the overflow holes from the freezer into the refrigerator section.
I emptied the freezer and took off the back panel. It actually wouldn't come off at first because all the water beneath the defrost heater which should have been draining out the drain hole was frozen into one solid block of ice. I used a hair dryer to melt the ice (took a while - be patient) and then took off the panel.
To melt all the rest of the ice in the drain tube I used the hair dryer. To clear out the ice in the drain tube, I used a turkey baster and kept putting down hot water until I heard water making it down to the evaporator tray beneath the refrigerator.
The following mod is "try at your own risk" (I wouldn't do this if you still have warranty coverage - call a tech instead):
I made this modification to prevent the problem from recurring (at least that's the hope): Wrapped a piece of wire (unbent a large paper clip) around the defrost cycle heater and stuck it into the drain hole. The theory is that the wire will heat up every time the defrost cycle runs and will keep the drain hole from freezing shut.
One thing I noticed during this repair concerns the drip pan beneath the defrost heater in the freezer (this is the pan that collects the water that is melted off the coils during defrosting). The drip pan does not seem to be angled properly so that the water will drain normally towards the drain hole. I guess water could remain behind then freeze later. I reported this to Whirlpool.
Mar 19, 2011 | Kenmore 64802 Top Freezer Refrigerator
Puddles on top shelf and under crisper drawers
This is not a major repair and also a very common problem. You will need to turn unit off and remove everything from inside the freezer. After this remove the back panel of the freezer and you will see ice built up at the bottom of the coils. You will have to remove all this ice and clear the defrost drain trough and tube. After the ice is removed you will see the defrost drain located about midways. Use a hair dryer to melt this then take a cup of very very very hot water and pour a little in the tube. Let stand for 5 minutes then dry it up real good and repeat. Do this till the drain clears and water flows freely. Then reassemble and you are good to go.
May 28, 2010 | Kenmore 64802 Top Freezer Refrigerator
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water is leaking on the top shelves in my kenmore refriderator water is leaking on the top shelves in my kenmore I have water leaking onto the top shelf of our Kenmore refrigerator. I believe it goes into...
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle. I'd also recommend checking to make sure the ice maker is not leaking.
May 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Roper Refrigerator, top freezer leaking water into refrigerator
This is usually caused by a plugged freezer drain. The back wall (or floor) of the freezer may come out to access the drain. Clear out anything visible and run a stiff wire thru it. Test with a cup of water. Hope this helps!
Dec 31, 2008 | Refrigerators
Water leaking inside refrigerator
Its the clogged defrost drain. I have the same problem. I just cant find the drain
Jun 06, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
199 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
