Question about Kenmore Elite HE5t Washer
Mine keeps flashing F 21 what does that mean?
  • Kenmore Master
  • 1,902 Answers
Hello
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Posted on Nov 09, 2010
I have a 1997 Dodge Stratus with Check engine codes as follows: Key ON,OFF,ON,OFF,ON codes 12, 34, 21, 55 I understand 12 is recent disconnected battery & 55 is end of test, but can't find definition of...
Jeff: Go to "Allpar dot com" website and look for a complete list of codes for the older Chryslers. From mine I remember code 34 as having at least two posible meanings: a) EGR Solenoid circuit problema, and b) Speed control problema. Code 21 means a problema in the Oxygen sensor. Amclaussen.
Aug 23, 2013 | 1997 Dodge Stratus
F-21 on a Bosch 1400s- what does this mean
F21 Motor fault. Call customer service. (NOTE: if the motor brushes are worn, these can be replaced by a competent person).
May 20, 2012 | Washing Machines
No what should i do know, don't have tool scanner
Try turning ignition switch thre times, without start engine ( ON / Off / ON / Off / ON ) and count the blinks light two short means a 2, space and one short flash measn 1, so code 21.
Keep us updated.
Oct 15, 2011 | 1994 Plymouth Voyager
My 05 subaru outback's odometer keeps flashing .ill.3 and ill.4 what does it mean
ILLUMINATION is set at 3 or 4 (the dimmer/brighter switch on the dash lights) Mine was flashing and dimmer switch had to be replaced.
Dec 12, 2009 | 2005 Subaru Outback
F-21 flashing washer stops
The F-21 means slow drain. There is a filter in the front of the machine, you have to remove the bottom front piece to get to it. The screws are on the bottom. You then will have to open the filter. It is a white tube. Mine was pretty tight. Be prepared for water to pour out. I have had to empty mine twice in the 2 years I have had it. Hope this helps.
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MY CABRIO SAYS SD ON THE DISPLAY
That means that the machine is sensing excessive suds. I just got the same message on my Duet today. The problem with mine, however, is that there is an issue with drainage. We emptied the drain filter and are currently trying to get it to work properly. It switched from Sd to F-21 and has repeated F-21 5 times until just now when it continued on in the drain/spin cycle to actually spin the clothes. Will keep you posted...
Aug 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Fault code f21
There is a clog in your hose. It happened to me, same washer. I took the hose off and blew into it, the clog came out.
Dec 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE5t Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
