Question about Whirlpool Dishwashers
Whats the difference between a GC2000 PE and XE waste disposer?
  • Bob Hamilton Aug 09, 2013
    The PE includes a plug-in power cord while the XE is a hardwired version that includes no cord.
How to replace a Garbage disposal
If you buy a similar model from the same manufacturer, you can leave the sink fittings in place. Unplug the power and disconnect the waste pipe. Undo the bayonet fitting securing the waste disposal unit to the sink fitting. Fit new unit to sink fitting, reconnect waste pipe and power. Run the unit with plenty of water to check for leaks. Job done.
Dec 04, 2015 | Garbage Disposals
Tip
How to unclog a garbage disposal
Before you tackle this problem, you should understand how to use your disposer so you'll probably never have to deal with a clog again. You can easily use put a sinkfull of waste down your disposer without a hitch. It's all about controlling the amount of water mixed in with the waste. Your disposer is designed to break waste down to pieces a little smaller than a BB. This is efficient but without much water, the pieces will clump together right where the disposer connects to the drain line, and will cause a clog. Never turn on the disposer without a full flow of cold water. Cold water not only helps to cool the motor, but keeps any fat solidified so that it doesn't build up on the walls of the pipes. The full flow of water will allow the disposer to mix the waste in and it'll go right down the drain. The second thing you must control is the amount of waste that goes in the disposer. It's really a bad idea to put more than like half a cup of waste in the disposer without it running. Ideally you'd turn on the water first, then start the disposer, then feed the waste in. Listen to the disposer running with waste in it. It sounds different when the waste inside is gone. Use this to get yourself used to keeping up with its pace. The problem with any disposer is that they work so fast, they can grind the waste faster than the water can carry it away.
Whatever you do, don't use a chemical unclogging product. Over time, this can damage the metal components of the disposer, and if you have to call a plumber, they will charge you extra because these chemicals make their equipment wear prematurely and can burn the skin.
If water doesn't drain, make sure the problem isn't fixed by simply turning the disposal on. If the water just swirls around, you'll probably need a plunger. When you want to use a plunger to unclog your disposal, the easiest way is to use suction more than pressure. When you push down on the plunger, the pressure from it will cause the backed-up waste to compress even further and make it impossible to push water down. You want to push the plunger down so that it "leaks" water out, and, when the plunger can be pushed down no farther, make sure it then has a good seal on the disposal's opening, and yank the plunger up pretty hard. This will pull the backed up waste back, mixing it with the water and will probably unclog the unit in only a couple strokes. Be careful not to soak yourself when pulling up on the plunger. In a pinch, a full soda can will actually form a seal and can be used in place of a plunger for disposals that have a splash guard made of one piece. If water is backed up into the other sink bowl, that means the clog is in the trap and not in the disposer itself. One way to fix this is to make sure the other bowl(s) of the sink are firmly stopped up. If you use a stopper you'll most likely have to push down hard on the stopper while plunging the disposer to form a good seal. If none of this helps, you may need to take apart the sink trap. This can be done by loosening the two nuts on the part of the drain pipe assembly shaped like a "U". You then may be able to clean the clog directly out of the u-bend or you may need to snake the pipes. If you take the pipes apart, have a bucket under there to catch the large amount of that will gush out.
on Dec 07, 2009 | Plumbing
Whirlpool gc2000 garbage disposal leaks from bottom of unit
if the leak is minor, spray Leak stoppers available at hardware stores. if major, may be a gasket needs replacement.
Oct 10, 2013 | Brasstech 113/01 Garbage Disposer Stopper,...
Is there an override button is not clearing garbage
If disposal is not running, then push red reset button located bottom of disposal.
If disposal is clogged, Clean out drain line under sink, and bottom of disposal under cutter blade.
Copy following link for clogged disposal.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Oct 19, 2012 | Badger 1 Insinkerator 76039h 1/3 Hp Feed...
Frigidare dishwasher did not spin
  1. Waste Disposal/Sink trap
    • Empty your food waste disposal unit if your dishwasher's hooked up to one. If it's not empty, the old food inside it will back water up into your machine. Check that your sink trap isn't blocked by unscrewing it from the base of your sink if you don't have a food waste disposal unit. Make sure your dishwasher or any other appliances connected to it are not running when you do so.
    Incomplete Cycle
    • You may have opened your dishwasher's door mid-cycle before it's had a chance to drain. Check the progress indicator on your machine's control panel. The structure of this will differ depending on which Frigidaire model you're using, but it should show the point your machine has reached in its cycle. If this is the cause of the problem, close your dishwasher's door and let it finish.
    Drainage Pipe
    • Inspect the drain pipe that runs from your machine to your waste disposal unit or sink. If this is kinked or has been squashed under another appliance or a base unit, the waste water inside your dishwasher will be unable to escape. Check that water can flow through your waste pipe freely.
    Filter
    • Remove the bottom shelf from inside your machine and take out the plate covering the filter area. If you don't rinse your plates before you put them into your washer, food debris could block your filter and stop water from reaching your drainage pipe. You can unblock your filter with your fingers. Turn off your machine's power before you attempt to do so.
Feb 02, 2012 | Dishwashers
Can not find waste ink disposer on canonpixma
The waste ink disposer on canon pixma mp150 is in the bottom of the printer.You must disassembly the hole printer to find and replace it.
Oct 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Dishwashers Logo
1,149 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
