Question about Vacuums
Bunning smell. How do I determine if it's the motor or the mother board? As there is no smoke coming out of the vacuum.
  • 1,673 Answers
Is it an electrical smell or a rubber type smell. If there is no smoke, it could be that the belt is slipping and causing a smell. If it is the motor, usually it would smoke, or at least quit running and making strange noises.
Posted on Jun 17, 2008
Hoover vacuum started smoking
Sounds like the roller became stuck and the motor burnt the belt into. I worked on Hovers for years and that is the most common problem.
Apr 02, 2014 | Hoover U5750-900 WindTunnel Bagless...
When running it smells like something is burning
If it smells like burning rubber, then your belt is probably slipping due to having lost tension and needs to be replaced. If it's another smell, it could be the motor burning out, but that is often accompanied by smoke. There could also be something caught around the revolving brushes in the cleaning head. Lie the vacuum on it's side and make sure you can spin the brushbar freely by hand. Also check for any debris entangled in or obstructing the brushes. This would also cause the belt to slip resulting in a smell of burning rubber. It could also damage the motor so I suggest not using the vacuum until the source of the fault has been determined.
Instructions on replacing the belt can be found in your user manual. If you don't have one or need further instruction on how to do this, please post back for further assistance.
Nov 25, 2010 | Eureka Capture Upright Vacuum Vacuum
I have Hoover Widepath Bagless 12 Amp Windtunnel vacuum. Yesterday I was vacuuming and smelled smoke and it shut itself off. Today I cleaned out the filters (they weren't bad) made sure nothing was...
Hi There,
When a vacuum cleaner smokes, it is usually only one of two possible problems.
It could either be that your motor burned up, or that your belts burned. The belts on this particular model are notorious for breaking, but the fact that your machine doesn't come on at all after this happened, sounds like it may be the motor.
Both of these issues have a unique smelling smoke. If the smoke smelled like an electrical burning smell, this indicates it's your motor. If the smoke smelled more like burning rubber, then it's probably your belts.
If the smoke smelled like burning rubber, here's a video that we've recorded showing step by step how to inspect, trouble shoot, and replace the belts on your vacuum cleaner. If you open it up and the belts are still in tact, then this probably is a more serious problem of the motor burning out.
. I'd be more then happy to walk you through more advanced diagnosing if this doesn't fix your problem, please just use the comment box here on the Fixya repair page.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me. This is really appreciated by the Fixya community if the repair solution was able to fix your problem.
Thanks again,
Chris Jones
Jun 14, 2010 | Hoover Self-Propelled WindTunnel Bagless...
When i vacuum it smells and so i turn it off. the
The belt is probably worn and slipping, that is why it smells. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 17, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Smoke and bad smell coming from the base
you need a nw belt but before you change the belt clean the burnt rubber off the motor shaft or your new belt won't last
Apr 03, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Burning smell comes from miele vacuum
You will have to open it up to see if it is a circuit board or the motor that is causing the smoking.
May 20, 2008 | Miele Vacuums
I don't know in Nev. call Hoover's 800 number and they will tell you, the number is on the metal tag. But if it is the motor smoking, a motor will run you $85 to $95, plus labor, $40 to $50. But if this an electrical smell, then suspect the motor. But if it is a rbber smell, then maybe you have a belt that is slipping badly, replace the belt.
May 12, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Savvy runs but has a burning smell...
Could be that the motor went bad, or one of the circuit boards is bad. The brush roll motor is the likely suspect.
Apr 14, 2008 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Burning smell and smoke
When you turn it the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
go to thehooverstore - this site lists a whole bunch of hoover machines, exploded diagrams and parts lists.
Aug 11, 2007 | Hoover Soft Light Supreme U4262-930 Bagged...
Vacuums Logo
329 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
