Where do I buy replacement hood trim - Computers & Internet
  • 943 Answers
You can go to ebay.com and search on there. you are sure to get what you need.hope this was helpful?
Posted on Nov 09, 2010
Best (Broan) K260A - I tried to change the bulb as well....completely inaccessible to change with hands (bulb is set deeper in hood, not even flush) tried gloves, rubber jar opener but cannot get access to...
The lamp holder assembly snaps into a hole in the range hood with spring clips. To remove the light bulbs, you simply push and turn, like older, bayonet style automotive turn signal bulbs. It seems you have broken your lamp holder assembly. Just break the trim ring so it can be removed, or you can try to take it out reverse polish style by releasing the spring clips from the middle inwards. Once the trim ring is loose, you can extract the body of the lamp holder through the hole... the wires will be barely long enough to stick out the hole if you are lucky. If you are crafty, you may fashion a repair on the separated lamp socket assembly. If not, your replacement part number is SV16569. just call nutone-broan at 800-558-1711 and they will be glad to ship you a new lamp shell socket trim assembly.
25439092-xipalmoknr3fbjmp51kycajc-3-0.jpg Retail on that part is around $50.
http://cdn.appliancepartspros.com/images/product/cache/broan-light-fixture-assy-sv16569-ap5178165_01_l.jpg
Feb 16, 2015 | Cars & Trucks
How-To Replace The Door Handle On A Kitchenaid Microwave Hood
behind door their is trim round the door use flat knife go between the trim will pop out and open 2 sc
Feb 01, 2015 | KitchenAid KHMS2050SSS Microwave Oven
Replace ge oven door vent trim
go to this web page and proceed according:
www.ehow.com/info_12181116_install-side-trim-oven-door-whirpool-gas-range.html
God bless you
May 09, 2012 | GE Stove/Oven/RanVent Trim - WB07T10230
Loose hood cord 95' civic, first I had to push the little latch that makes the hood shut completely with a screw driver now it won't even open (the hood) I pulled on the cable with pliers but no...
Just perform some checks please,
  • try to pull the hood release lever with its cable tightly pulled towards you.
  • that may tighten the loose cable so a release can happen
  • then pull out the hood piece hard, so the lock would release.
  • trimming is not a good idea, because it would be hard to set it back into the assembly.
  • try this, good luck. vote it!!
Sep 24, 2011 | 1995 Honda Civic
How do i replace a head light, high beam
remove trim piece surrounding light, this is like 4 star bolts in trim and 2 in top of trim under hood, once removed this will allow access to small screws holding light bulb ring, remove screws and un plug light . replace in reverse order.
Mar 16, 2011 | 1991 Chevrolet K1500
How do you replace the light bulbs? There is a lens cover over the bulb.
This is how to replace the lights on the KitchenAid khlu162m hood. If this is not you hood please give the right make and model # so I can get you the right info.
Replacing the Halogen
lamps:
The hood liner uses 12-volt, 20
watt halogen lamp bulbs.
Before you begin, make sure that
the range hood is turned off and
that the lamps have had sufficient
time to cool.
To replace a halogen lamp:
• Remove 2 screws from the
circular metal trim around the
lamp assembly.
• Pull the trim with the lamp
assembly attached down far
enough so that the lamp can be
pushed out of the socket clips.
• Insert the new lamp into the
socket clips and push the lamp
and trim assembly back up into
the hood.
• Replace the screws.
Good Luck and please rate 4 thumbs up for the free answer.
Jun 13, 2010 | KitchenAid KHLU162M Kitchen Hood
Bad smell in air vent chevy impala
MILDEW ODORS.YOU CAN GO TO AUTO PARTS PLACE BY A CAN OF AEROSOL DISINFECTANTS FOR AUTOMOBILES ON THE CAN .IT HAS INSTRUCTION TO TELL YOU HOW TO USE IT.
Oct 05, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
Remove door lock and replace
Yes, the window frame and window glass need removing. Make sure to buy some trim clips, and I'd advise buying a trim tool also to avoid busting the thin mdf the trim is backed with.
Apr 01, 2009 | 2003 Land Rover Discovery
Took off trim around lightbulb
Place the circle of the springs on the two small post that are in the center piece of the trim that heads into the hood, make sure that the two legs of the springs are to the outside of the post. The small legs should lay against outside the center piece. The larger legs should be angled downward. Look in the hood and you should see a piece of metal with a central vertical opening on each side. Take the trim piece with the springs attached and lift the wings of the springs so that they enter the slits. The important part is that the small legs of the springs must be placed against the outside surtace of the hood. As you push the trim piece in the hood the wings of the spring will be forced down through the slits by the pressure of the small legs of the spring against the exterior of the surface of the hood. This pressure will keep the trim piece in place. It may help to remove the filters so that you can see inside of the hood. Make sure that the small legs of the spring are against the outside surface of the hood or there will not be any resistance to create pressure by the springs.
Mar 16, 2009 | Dacor EHD3618SS Kitchen Hood
Power door lock switch replacement
Remove or Disconnect
Door handle trim plate.
  1. .Install or Connect
  2. Electrical connector and door lock cable.
  3. Trim panel by engaging hooks on backside of panel.
  4. Push pin fastener in defroster duct.
  5. Screw from behind lamp assembly.
  6. Courtesy lamp assembly.
  7. Two screws in arm rest.
  8. Arm rest cover plate.
  9. Door handle trim plate.
There May Be A Need to Drill Out RIVETS that Hold Motor in place,. Just Replace with>>MACHINED SCREWS & BOLT'S
  1. Trim panel. See: Doors, Hood and Trunk\Doors
  2. Four tabs retaining switch.
  3. Electrical connector.
Install or Connect
  1. Electrical connector.
  2. Snap switch into trim panel.
  3. Trim panel.
Mar 14, 2009 | 2000 Buick Park Avenue
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
