Question about Apple iPhone 3GS Black (16 GB)
Where does a sim card go in iphone - Apple iPhone 3GS Black (16 GB)
  • 943 Answers
Depending on the model of the iphone, it usually goes in from one of the openable slots on the surface of the phone. that is, you need to look at the top, side and all round the width of the phone and you would find a slot which you can insert the sim card
Posted on Nov 09, 2010
Does my zte800 have a sim card?
Remove or switch the SIM card in your iPhone or iPad - Apple
https://support.apple.com/en-us/HT201337
AppleDec 11, 2015 - After you remove or transfer your SIM card, insert the tray completely and in the same ... For example, a SIM tray from an iPhone 6 will not fit in an iPhone 6s. ... Find out which SIM card your devices uses. ... Shop the Apple Online Store (1-800-MY-APPLE), visit an Apple Retail Store , or find a reseller .
Why Does My iPhone Say No SIM Card? Here's The Real Fix!
www.payetteforward.com > Tech Blog > iPhone
Nov 28, 2014 - You didn't take the SIM card out of your iPhone, and now you can'tmake phone calls, send or receive text messages, or use mobile data.
Does iPhone have a SIM card? - EveryMac.com
www.everymac.com/.../iphone-sim-card-troubleshooting-...
EveryMac.comHow to access the iPhone SIM card, which iPhone models have Mini, Micro and NanoSIM cards and how to upgrade from an old iPhone to a new iPhone.
Jan 12, 2016 | Cell Phones
Vodafone uk
No The sim card for the older models is not the same size as the new iPhone 5. You can take your old sim card to your provider and they can make you a sim card to fit your new phone.
Aug 10, 2014 | Apple iPhone 3G
Transfer contcs from a blackberry curve9350 to apple 3gs
u cant transfer it directly but u can transfer them to outlook and when u connect ur iphone to the pc u can choose to sync the contacts with outlook.
good luck
Feb 14, 2013 | Apple iPhone 3G
Tried to restore my iphone 3G OS 3.1.2 in the itunes. after the restoration process was complete the following message appeared " the SIM card inserted in this iphone does not appear to be supported" "only...
do as it says you need a valid SIM to restore an iphone and it is possible to have a SIM go bad. There is nothing that can be done until your sim is infact working and valid and it MUST be an AT&T sim no other sim will work for restore.
Oct 18, 2010 | Computers & Internet
Where to insert sim card in iphone 3gs
At the top of the iPhone you will see a small hole. Use a paperclip to push in the hole and the sim card try will pop out.
Put your sim card in the tray and put back in the iPhone
Dec 25, 2009 | Apple iPhone Smartphone
Sim card causes iPhone to overheat and drains the battery.
I've tried to lock the iPhone to my tele provider in stead of letting it search for available networks (the automatic option in settings). Seems to work. But I will also get a new sim card. Strange problem though...
Sep 09, 2009 | Apple iPhone Smartphone
How to put sim card to the iphone?
SIM card slot is in top of iPhone. From iPhone Manual:
If your SIM card was not preinstalled, you must install the SIM card before you can use iPhone.
Install the SIM card:
1 Insert the end of the SIM eject tool into the hole on the SIM tray.
Press firmly and push it straight in until the tray pops out. If you don’t have a SIM eject tool, you can use the end of a paper clip.
2 Pull out the SIM tray and place the SIM card in the tray. The angled corner of the SIM ensures that the card fits only the correct way in the tray.
3 With the tray aligned as shown, carefully replace the SIM tray containing the SIM card in iPhone.
Aug 11, 2009 | Apple iPhone Smartphone
How to change the simcard of my apple 3g iphone?
The SIM card in the iPhone is removable, but it's hidden. To remove the SIM card, you need a paper clip.
We are checking to see if this voids your iPhone warranty. If you are concerned that it might, please don't perform this task.
The iPhone's SIM card is located behind this door.
1. Locate the SIM Card Slot
The slot is located at the top of the iPhone, between the headphone jack and the power button.
The paper clip is a valuable tech tool.
2. Open the Slot
Take your paper clip and insert it into the little hole. Then firmly push down until the slot pops up.
3. Remove the SIM Card
The SIM card is in a cradle. You can pop the card out of the cradle.
To replace the SIM card, put the card back in the cradle. The cradle and card are notched in a way that forces you to replace the card on the proper side. Then just slide the card back into the iPhone.
Thanks alot,
Sanjeev Kumar
Jan 22, 2009 | Apple iPhone 3G
Iphone
this is what you do
  1. get a unlock card Click Here
  2. get a Verizon Sim card click here
  3. Switch off 3G network: Setting---General---Network---Enable 3G---Off
  4. Turn off the iPhone 3G, take out the SIM tray, place the Unlock Card and the SIM card on the SIM tray, put back the SIM tray into the iPhone
  5. Turn on the iPhone
    There is NO NEED TO CUT YOUR SIM!
  6. Just Plug & Play!
Jan 16, 2008 | Apple iPhone Smartphone
2 Problems..Sim Card Problems
Well, first off, an iPhone won't work at all with a T-Mobile SIM card. American iPhones are locked to AT&T's network -- only AT&T SIM cards will work in them.
As far as activating it with AT&T, make sure that the iPhone isn't connected to the computer while you install iTunes. Once iTunes is installed, connect the iPhone to the computer and iTunes should launch automatically and begin the activation wizard. Just follow the instructions on the screen and answer the questions.
Dec 05, 2007 | Computers & Internet
Apple iPhone 3GS Black (16 GB) Logo
43 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
