Question about Acer Computers & Internet
Broadcom UNDI PXE-2.1 v11.0.6 Copyright (C) 2000-2007 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation All rights reserved PXE-E61: Media test failure, check cable PXE-MOF: Exiting Broadcom PXE ROM. Operating System not found
elix0411
  • 3530 Answers
SOURCE: Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Apr 04, 2010
  • 162 Answers
Hi. I think the problem on this one is its either your Harddrive has already failed or your Optical Drive has a cd inside, so double check your Optical drive if there is a disc inside it. If not this issue is also with the operating system, you can try to restore your system by pressing the One Key recovery(OKR) button found beside the power button which has a logo of an arching arrow, but remember to plugin first the ac adapter on your laptop before pressing the One Key Recovery Button and also do not press the power button to turn on your computer because when you press the OKR button it will automatically turn on your computer and proceed with the recovery process. When it gives you some option you should choose One Key Recovery and then choose System Recovery, then factory default and from there it will guide you to the whole process of recovering your machine. If this doesnt fix the issue you could also try using the Recovery disc to restore your sytem t its original settings just like the OKR. Lastly you can contact the tech support dept. of Lenovo, they are open 24/7 and this the number to contact:
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope this helps
Posted on Jun 03, 2010
parrotheadpc
  • 2600 Answers
SOURCE: Broadcom UNDI PXE 2.1 v11 . 4.1
This is showing because the computer is not seeing the hard drive that contains the operating system. In some cases this is because the hard drive has come dislodged from the interface on the motherboard. Dells are good for this because the hard drive slides into the side of some models. Try reseating the hard drive and reboot. Your worse case scenario is that your hard drive has failed. The reason you are seeing the PXE-MOF etc. is that the laptop ias now looking for a network hard drive to boot from. It can't find the intenal hard drive so it is searching for other means to boot.
Posted on Jun 16, 2010
yuvamibar
  • 170 Answers
SOURCE: Hi, When I turn on my
usually, this message means that when your computer is booting it is trying get the operating system files from a network location (shared folder)
what you need to do is to make sure your BIOS is not set to boot from network.
1. when the computer starts, there is a message like "to enter BIOS press Esc" or any other key like F2 or F10
2. in the BIOs settings, make sure the order of the boot is: DVD/CD then hard disk. make sure there is no Network booting in the list
Posted on Oct 26, 2010
  • 34 Answers
SOURCE: went to shut down comp. and screen said, and still
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Posted on Dec 05, 2010
First ther was a error message, then the pc make nothing.
If you have a spike in the power, unplug, remove the battery, then hold the power button down for 1min or 60s, to release any built up shock power. then insert the battery, (no power cord) push and hold power button for 1 -2 - 3 s. release and see what happens.. now what OS is installed on the HDD. and check the BIOS to see how the boot sequence is set... seems your error show you set to boot to NetWork not HDD
May 28, 2014 | Acer Aspire 5500 5570-2609 Laptop
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
Hi, When I turn on my Laptop - Acer Aspire 5536, the following writing appears; Broadcom UNDI PXE-2.1 v11 .4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel...
Oct 26, 2010 | Acer Aspire 3690-2196 Notebook
I was using my laptop last night when it just shut down on me, then when i went to turn it back on it goes to the acer "start up" like page before skipping to a black screen and displaying the following...
If you have a BOOT CD then try to boot and go to windows.
Or you can use windows setup CD but go for repair only.
For the future it is a good idea to INSTALL WINDOWS in a USB mini drive and boot the computer from USB. You have to go to BIOS and set USB default drive.
It is a good idea to clone your HD in a CD.
Sep 04, 2010 | Acer Aspire 3690-2196 Notebook
I have Dell Studio 1555, Vista but later intalled XP on drive D, I have problem my CD/DVD drive does not read the Data, CD does not revolve in high speed make the tak tak sound as it try to read bit after...
Your message indicates that Pxe Boot is enabled (boot from lan card), go to bios settings and from the list of first boot options, please select the hard disk (hdd) or Cd-rom as the first boot device, reboot your system and check whether this helps or not.
It is also necessary to disconnect and reconnect your dvd/cd rom's power cable and data cable.
If you don't know how to do, then just reset the bios settings to "load default" ...
Good luck.
Thanks for using FixYa.
Jun 24, 2010 | Computers & Internet
Broadcom UNDI PXE 2.1 v11 . 4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation All rights reserved. Broadcom Base Code PXE- 2.1 v1.1.0 Copyright (C)...
Jun 16, 2010 | Acer Aspire 3690-2196 Notebook
Mar 31, 2010 | Lenovo 3000 G530 Notebook
I brought the computter about month ago.. and now its appears ::
This is a common problem but there may be more than one fix
The easiest is to go to your bios and set the boot device order.
It is quite conceivable that it is set to try and boot from network first
You should select HARD DRIVE or CD DRIVE as you first option and then reverse that order for your second boot device
Aug 20, 2009 | Lenovo ThinkPad T41 Notebook
My acer aspire 5315 is stuck on dis screen, n I don't have a recovery disk to reformat it, wat can I do? Broadcom UNDI PXE-2.1 v10.0.9 Copyright (C) 2000-2006 Broadcom Corporation Copyright (C) 1997-2000...
your operating system is broken. or infected by virus, file corrupted.. neet to repair if could.. but if not re install the os...
save first all the inportand documents in external hdd or in drive d before to start re install the os
Jun 14, 2009 | Computers & Internet
Video card failure replace your video card
Feb 10, 2009 | Lenovo ThinkPad T41 Notebook
Computers & Internet Logo
376 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
