Question about AmcorAire UCHW-H12AF2 Split System Air Conditioner
Flashing F1 display on status window. Unit will not start. It will chirp in response to remote control,but takes no action.
  • 73 Answers
What model do you have, the UCHW model is a 13 SEER and only displays error codes starting with the letter ' E '
Email: Support@Pridiom.com
Posted on Jan 04, 2011
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
Unit powers up but display is frozen and no nothing after that. No remote or button response except for display off.
The display microprocessor(computer within your unit) may be bad. This IC is responsible for processing any and all IR(infra red) commands from the remote, as well as scanning all the push buttons on the front of the unit. If you're interested in having your unit repair, please visit me website at audioserviceclinic.com. You may contact me there. Thank you.
Sep 04, 2015 | Pioneer X-smc3-s Music Tap Airplay Music...
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
On the remote I will push the unlock button, then the car's horn honks and unlocks the doors. It also honks when I want to lock it. I am only pushing the lock or unlock button once. I'm not in the...
You can disable the chirp confirmation by using the following procedure
1. Turn the ignition on
2. Turn the ignition off
3. Press the valet switch 5 times, wait for the Status Light to flash twice, the parking lights to flash twice and the horn to chirp twice.
4. Press the valet switch 4 times, the MARS unit will respond with 4 Status Light flashes and horn chirps
5. Press the transmitter START button, the MARS unit will respond with 3 Status Light flashes and horn chirps
6. Turn thr ignition on to exit program mode
May 08, 2011 | Omega MARS-22 Remote Vehicle Starter with...
I'm trying to install a Python 991 Remote Start / Car Alarm in an automatic 2000 Subaru Impreza and I have all the wires set up. I know the Control center is supposed to be switch from manual to automatic...
It is not the "control center" that needs to be switched. The unit itself must be programmed for automatic transmission. The antenna (control center) must be connected to the module for normal operation. Merely connecting the two does not initiate a reaction from the LED. You MUST enter the programming mode (ignition on , ignition off, press and hold programming button until you hear three chirps from the siren). The three chirps are remote starter programming options. After you hear the three chirps, press and release the programming button once then, press and hold the button (you will hear one confirmation chirp), now press and release the lock button on the remote (you should hear two chirps from the system). The unit is now programmed for automatic transmission.
There are several other programming options for your particular vehicle (not mentioned) that may be NECESSARY for the proper operation.
Mar 20, 2011 | 991 Responder LC3 SST Security/Remote...
I recently had an avital 4103 remote start system installed in my 09 Chevy Silverado truck. The remote starts the truck perfectly everytime however the lock and unlock buttons dont unlock or lock everytime...
As an L1 ASE Master tech I ALWAYS advise against aftermarket alarm systems, however the problem you are experiencing is due to an action that is not being taken by the vehicles control modules. The installer should tie into the door control modules or find out why the body control module is recognizing the command for the locking/un-locking action, (hence the lighting response), but the doors are not taking appropriate action. I would have to look at live data in the vehicles control modules to see what modules are being commanded to do what. Take it back to the place where it was put in and tell them to fix it or refund it.
Nov 21, 2017 | 4103LX Remote Start System with Two...
The remotes for my system do not operate when I press the lock or unlock or remote start buttons. Is there a way that I can reprogram the two remotes to work with my remote start sytem. It is the python...
The "pair" the remote with your system:
1.PRESS AND HOLD the f button on the remote UNTIL the transmit LED lights solid (approximately 10 seconds)
2.PRESS AND HOLD the remote start button (circle arrow) UNTIL the LED blinks 3 times and the amber transmit LED lights up. Your remote is now ready to pair.
3.. Turn the key to the on position
4.Within 5 seconds PRESS AND RELEASE the control button on the antenna.
5. Within 5 seconds PRESS AND HOLD the control button. The status LED will flash one time and the siren will chirp to confirm that the system is ready for remote pairing.
6. Press lock button on remote. System will respond with chirp toconfirm pairing.
Oct 28, 2010 | 1401 Remote Start/Keyless Entry System
Nighthawk carbon monoxide alarm model KN-COPP-3. ( ERR appears in the window, what does this mean ....
Readings You May See When Unit is AC Powered
Display Shows Alarm Sound Unit Status Recommended Action
Steady "Err" "Chirp" every Unit malfunctioning when Call KIDDE customer
and flashing dot 30 seconds AC powered service at 1-800-880-6788
Readings You May See When Unit is on Temporary Battery Backup
Flashing dot None Normal battery-only operation - Plug in to AC as soon as
unit will show reading only if it possible to conserve battery
senses CO
Flashing dot and "Chirp" every Unit malfunctioning when Call KIDDE customer
"Err" 30 seconds battery powered service at 1-800-880-6788
Hope this helps. Manual is here:
http://www.detectorsandalarms.com/images/pdf/Manual_KN-COPP-3_900-0100en.pdf
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
Oct 26, 2010 | Computers & Internet
Stop horn from beeping on every action
You can delete the chirp from the unit: turn the ignition on, then off, press and release the programming switch three (3) times. You should hear two chirps. You should hear no sound from the unit now when commands are sent. You can put the chirps back in the same manner.
Oct 17, 2010 | Prestige Remote Start
Coleman 15k will not come on
Here is the troubleshooting guide for your unit. Hope this helps.
TROUBLE SHOOTING GUIDE
TROUBLESHOOTING
Symptom Remedy
1. Remote does not turn on system
- Check and replace remote batteries if the display fades while
any button is activated or no display is present. - Point remote towards IR receiver during transmission. 2. System does not turn on, no green LED & no beep
- Check wiring. (see "installation instruction")
- Check modular cable to receiver.
- Check diagnostic LED status in the upper unit control box.
3. System does not turn on even when receiver green LED is on.
- Low or over voltage condition, check diagnostic LED status in the upper unit control box.
4. Fan runs but no cold air.
- Evaporator temperature sensor reaches low limit, defrost mode.
5. System runs continuously in the cool mode
- Remote was set for "I feel" mode and is left in a heated environment (sun etc.)
6. System runs continuously in the heat mode
- Remote was set for "I feel" mode and is left in a cool environment
1. Diagnostic LED (green)
(Note: Located on the control board in the upper unit control box.)
a) The LED is on when the 12VDC is adequate and communications are
present.
b) The LED is flashing fast and steady when in the freeze mode. Evaporator has frozen and the freeze proctection switch is engaged.
c) The LED is flashing slow and steady when the delay on break timer is
activated.
d) The LED is flashing 1 cycle on and off for one second with high or low
12VDC. Check the incoming 12VDC power for OK.
e) The LED is flashing 2 cycles on and off for one second with a
communication problem. Problem with the control board in the unit and the remote.
Hope this helps.
Jeff
Rate me Please!!!
Jul 29, 2008 | Coleman Mach 15 Air Conditioner
AmcorAire  UCHW-H12AF2 Split System Air Conditioner Logo
416 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
