I bought a 93 civic dx but the oxygen sensor was missing. I purchased a bosch 02 sensor and need to install it but cant get a diagram or any help on figuring out the color combo .... on the car there is a white, orange w/black stripe, yellow w/black stripe, and a green w/white stripe however on the 02 sensor there is 2 white,1 black, and 1 grey. any suggestions?
posted 3 times now and forget to say FRONT SENSOR> right, not the Rear 02 sensor....? and still no engine stated.! nor country, (USA calif, usa FED, or canada) strike three you are out. sorry. there are 3 engines, based on all 3 engine schematics, my wild guess is 7AFE engine. (the brown wire clue) 1,8L 4AFE (1.6L) or 1ZZFE engine, DOHC 1.8L
There are a total of 4 02 sensors on your vehicle. Each side of the engine has 2 02 sensors. 1 sensor is located before the catalytic converter, and 1 sensor after the converter for each exhaust. You will have to remove the lower plastic covers under the car to access where the sensors are located. They are located in the exhaust forward of the transmission. You will need either a 22mm or 24mm open end wrench, or preferably an oxygen sensor removal tool which can be purchased from an automotive store or even Sears. In addition you may need a 3/8 ratchet.The sensors can be pricey and I recommend staying with Bosch brand if possible. It is best to remove the sensors when the exhaust is cold.
you need to borrow the oxygen sensor wrench from autozone or whereever you bought the sensor.
Section 03-14: Engine Controls, Electronic 1996 Taurus, Sable Workshop Manual
REMOVAL AND INSTALLATION
Heated Oxygen Sensor (HO2S)
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number
Oxygen Sensor Wrench T94P-9472-A
Removal and Installation
Disconnect battery ground cable (14301). Refer to Section 14-01 .
On 3.0L (4V) engine remove cowl extension and right side of leaf screen.
Disconnect engine control sensor wiring (12A581) from heated oxygen sensors (HO2S) (9F472). Do not remove harness connectors from the brackets.
Raise vehicle on hoist. Refer to Section 00-02 .
NOTE: If excessive force is needed to remove a heated oxygen sensor, lubricate the heated oxygen sensor with penetrating oil prior to removal.
Remove heated oxygen sensors from exhaust manifolds (9430) using Oxygen Sensor Wrench T94P-9472-A.
To install, reverse Removal procedure. Apply a coating of anti-sieze compound to threads of heated oxygen sensor. Tighten heated oxygen sensors to 34-46 Nm (26-34 lb-ft).
