Internet connection blinking lights
The lights on the back of my computer are solid green and blinking orange is this normal
  • tiesagraf Dec 02, 2008
    blinking battery light... i almost never use the laptop without the ac hookup - what is up???
  • 67 Answers
Yes this is normal. your system is working just fine.
Posted on Jun 18, 2008
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
I just reset my dell computer back to factory setting. How do I now reset up for internet connection. My provider is verizon and I am using internet explorer
You want to reset your internet connection???
If yes then follow the given steps....
Step 1
Turn the modem so that the back of it is facing you. Locate the power supply cord connected to the back of the device.
Step 2
Gently unplug the power supply cord and leave it unplugged for about 10 seconds. If you also have a router connected to the modem, disconnect the power cord of the router as well.
Step 3
After about 10 seconds reconnect the DSL modem power cord. Wait for the status lights on the front of the unit to come on. They may blink at first before turning solid green, or they may first illuminate as orange, then turn green, depending on the modem model. The "Internet" and "Incoming" lights may continue to flicker, this is normal operation for modems.
Step 4
After the modem is reset, reconnect the router power supply if you have a router. Wait a few minutes before resuming normal Internet use.
If you need any kind of technical assistance you can contact support cell
Jan 19, 2013 | Computers & Internet
N300 router has a steady orange blinking light
The blinking orange power light suggests that there is a problem with your modem. The modem should be plugged into the top ethernet port of your router. Try turning off your modem for 10 seconds and then turning it back on.
Dec 07, 2012 | Belkin Computers & Internet
Netgear wndr3300 blinking orange light
It depends. Have you checked the Netgear support site for FAQ and the manual. In some routers, orange lights indicate wired 100Mbps connections while green indicates 1000Mbps. In other cases, blinking lights indicated that the router is 'bricked'.
Sep 09, 2012 | NetGear WNDR3300-100UKS Wireless Router
ZyXEL Prestige 600 Series router failure
Not sure which specific router in the series you have but the following may help:
Well there should be a power light on and solid green, a DSL light solid green and on. The internet and ethernet lights should be blinking green if sending and recieving data.
I'll bet thats amber and not orange. In which case you have a 100mbps conenction to between the pc and router.
Check here for more details.
Aug 28, 2009 | Computers & Internet
I have a belkin wireless g router. Internet light keeps on blinking though I can surf the internet. Is this normal or should I have a solid light on the internet?
This is normal - indicates internet traffic. Don't worry about it so long as all the lights are green. The lights will turn orange if there is a fault of any kind.
Hope that helps!
Apr 05, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
186 people viewed this question
David Payne
David Payne
