Question about Samsung HP-R5012 Television
HP-R5012 I GET SOUND BUT THE PICTURE IS JUST A BUNCH OF COLORS MOVING ON THE SCREEN
5 Suggested Answers
  • 4090 Answers
SOURCE: hp-r5012
How long is a piece of string?
There are 2 boards called sustain boards inside the set. Either one of them or both could be the culprit. Unless you have electronic skill, the right tools and know how to retune the set, I would siuggest this is not a DIY job. Some willsay it is just a matter of unplugging the boards and replacing them, howver that is a short lived fix in a majority of the cases i read on here.
Yes it does work for a while, then other problems arise.. conergence drops out, power fails and a myriad of other things happen that would normally be measured and checked by a good repair technician. It ends up costing 2-3 times more than if it was done professionally. The decision is yours, but i can only advise you NOT to.
Thanks for using FIXYA
Posted on Sep 27, 2009
nikeananth
  • 267 Answers
SOURCE: horizontal lines and colored snow
HI,
There are three likely causes for horizontal lines on your plasma TV.
1) A bad incoming signal. Do you see the lines on every channel, and from every source? If you play a DVD or videotape and the lines are still there, then that rules out your cable television or satellite box if you have one. However, if you find that the lines disappear when you play a DVD, I would contact the support desk for your cable or satellite provider.
2) A burn-in. This is caused by things like excessive use of video games or watching TV programs that have static (unchanging elements) like icons or scores or even lines. Have you tried using the built-in burn-in cleanup utility that is part of most Samsung plasma sets? Even if you suspect that the problem is not caused by burn-in i would recommend you try this just to see if it has an effect.
3) A problem with the electronics. Here you have to asnwer the following: is your set still under warranty? Most plasmas come with a one- or two-year warranty. If you paid for the set with certain types of credit cards, your warranty may be extended by a year or so: call your credit card.
If the set is still under warranty, immediately arrange for a repair and keep a record of all dates, names, phone numbers, and promises made. Don't accept any statement that five horizontal lines is "acceptable" to the maker; a pixel here or there may be excused but not a serious problem like yours.
Finally, if your set is NOT under warranty, consider carefully whether to make a repair or buy a new set. New set prices have dropped sharply, and the difference between a repair and a new set may not be significant. Of course, you can wait until the set fails.
thank you,
vijay
Posted on Sep 29, 2009
siteseeker
SOURCE: screen has color. but no picture.
Unscrew the cable off the cable box on the out to TV end, then screw it back on. You may also try a different type of cable, like HDMI or component cable.
Posted on Dec 28, 2009
toolkits
  • 1099 Answers
SOURCE: I have a 5 yr old Samsung HP-R5012 Plasma Display
All plasma an lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Posted on Aug 11, 2010
Samsung hp r5012
Power Supply has one or more bad capacitors. Look for leaking or puffed capacitors/usually 10vdc. Increase the working voltage of the replacement capacitors while keeping the microfarads the same: sample: if original is 1000 microfarads @ 10vdc replace with 1000 microfarads @ 16vdc.
Mar 15, 2014 | Televison & Video
Plasma TV has a black uneven splotch in the middle of the screen
hmmm. sounds like the screen might be damaged. You might have to get a new one. But before you do that I would try leaving it off for a while maybe a few hours or so and see if that helps.
Jul 10, 2017 | Televison & Video
I have a Samsung Plasma HP-r5012 that has sound but no pix. I had a repair man out and he said the main board needed replacing. I've decided to try and do it myself. I've found what I think is the part...
U never done tv repair before,not sure about the parts or u think can't do it.Don't tries it.Shop for a new tv first and compare the repair priced that was quoted,if it cost more than half of the priced of a new tv.My opinion buy a new tv,prices are dropping very fast on Plasma and LCD tvs all models.
Nov 07, 2010 | Samsung HP-R5012 Television
I have a 5 yr old Samsung HP-R5012 Plasma Display Television. A display model. Last night, horizontal lines appeared, then, the top half of the screen went black, with color pink and blue surrounding the...
Good luck.
Aug 11, 2010 | Samsung HP-R4262 42 in. Plasma Television
Samsung HP-R5012
They didn't fix the issue this last time. The most common failure in these models is the upper and lower Y buffer boards. There are updated versions and both must be replaced as a pair. The part numbers are as follows: BN96-03361A for upper Y board and BN96-03362A for the lower Y board. Please take a few moments to rate my answer. Thanks...
Nov 20, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
Hp-r5012
Sep 27, 2009 | Philips 42PF7220A 42 in. Plasma Television
1/2 screen blacked out
There is a couple of problems that will cause this symptom. The lower y-buffer board, y-sustain board, or the z/x-sustain board, on rare occasions the power supply. Most manufacturers tech support recommend replacing the buffer and the sustain boards, because there is no easy to isolate the problem. The easiest way is to swap boards till you find which one is bad, and this gets expensive. The buffers range from $75 and up, and the sustaines from $250 up to $400 each.
Aug 30, 2009 | Samsung HP-R5012 Television
Samsung HP-R5012 Television Logo
46 people viewed this question
Jerry Greenberg
Jerry Greenberg
