Question about Canon imageRUNNER 210S Copier
The copies are very light. I have tried to adjust exposure, no change. I have already added toner. drum? fuser? Clean...what?
  • 1,219 Answers
firstly clean the beneath the copyglass and clean the optics ( mirrors ), then try...
also try to darker the copy and see what happens, if its still light try to change the drum....
PS are you using the original Canon toner?
Posted on Nov 16, 2010
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
Produces Light Copies
Have you considered changing or checking the toner cartridge?
Does it display a low toner light?
I had a similar problem with a copy machine, where ALL the settings were correct and the toner was light.
The problem was the toner cartridge, the toner was caking because of the temperature. All it took was a good shake at the toner cartridge and it worked.
Also, check to see if the scan bed is messy, a good cleaning the the scanner bed should work as well.
Hope That helps!
Dec 12, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
Duplicate print below each line on copies/printing/fax, changed fuser unit and drum unit and had cleaned. Seems to happen after toner changes, can the toner cartridge holder be defective and cause this...
Try to stop the copier (by jamming a sensor or opening a cover) mid-way through the printing cycle. Remove the 1/2 copied document out from the drum area. Look to see if you have the double printing. This will eliminate the fuser as the problem. If you don't have the double printing then the fuser's cleaning roller may be shot causing repeat image. If it is in the drum area it will be hard to determine since you already replaced the drum(?). But there is a "cleaning" lamp or charge wire on the drum to check.
Aug 10, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Added toner/copies still too light
adding toner to Canon copiers will not fix copy Quality problems. Do the copies look better if you manually adjust your exposure setting? If so you can clean the optics, which are the mirrors under the glass. Be very careful there are alot of sharp metal edges, that can cut you very easily.
You can use windex.
Apr 10, 2009 | Office Equipment & Supplies
White line and very, very dirty copies
the nealy black copies sounds like the drum is going, try adjusting the exposure to light, if it comes out with the whole page the same way but just lighter than change drum. White line sounds like there is something on the coronas.
Jul 22, 2008 | Canon PC-940 Black and White Copier
Light copies
If you have changed all you mentioned with the correct parts, I can only advice you to change the control board.
Try to warm your papers
The same power you are using now, is it the same you have been using before facing this light copy problem?
May 08, 2008 | Canon NP 6050 Copier
FP 4080
Hello Bob,
Where are you located? You should be able to find the toner for this machine. Have you tried www.precisionroller.com ?
I am almost positive that they carry the toner and also consumable part as well as replacement parts.
One of the reasons the copies might be dirty, is that the optics, charge wires, cleaning blade, drum, and or fuser unit might need some parts replaced. Without seeing a copy of what the machine is actually doing, or looking at the machine, it's hard to pin point exactly what is going on.
If you have any questions with the machine, feel free to post any questions and I will be glad to help you.
Good luck.
Hope this helps.
Mac =)
Feb 29, 2008 | Panasonic FP-7735 Black and White Copier
Replaced both toner and drum- prints too light
remove drom and toner, in base of machine is a glass slit, clean it.
Oct 14, 2007 | Brother MFC 6800 All-In-One Laser Printer
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
Dark Copies
Jim, A couple of things: 1. OEM (Canon original) toner cartridge or remanufactured/compatible? The first place to start is always with the toner cartridge when image problems occur. Pull the cartridge out and draw back the drum cover. Check to see if the drum is a nice "clean" blue color or if the lines and spots are on it like you described. (These two areas should be handled by someone with experience in copy service) 2. The next thing would involved cleaning under the copy glass. Build up from dust, etc causes a "fogginess" that makes the machine try to adjust the intensity of the exposure lamp to conpensate for this. 3. Also could be a bad upper fuser roller if you started having any paper jams when to paper exits.
Jul 18, 2007 | Canon imageCLASS D320 Digital Copier
Canon imageRUNNER 210S Copier Logo
81 people viewed this question
old marine
old marine
