Posted on Nov 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pictures are coming out kinda pink or light red
Anonymous
Level 3:
  • Master 340 Answers
  • Posted on Nov 09, 2010
Anonymous
Master
Level 3:
Answers
340
Questions
0
Helped
83589
Points
1012
You may be running out of color ink.. try cleaning the heads of your cartridges by going into your devices and printer file and clicking on your printer listed, then you will need to go into the maintenance of it and clean the heads. This should work
Fuji Finepix V10 Red Pink Hue in pictures and on LCD
Sounds like the sensor ribbon has slightly come out of it's socket.
Just needs re seating
Red tint,double pictured red, kinda swirly
Replace Both of your STK ICS they will have Part number on them example STK392-110 if 110s use 150s Call Mats 1-800-628-1118
I plug in the TV and the red light comes on but no
if you are not handy with electronics, and have the tools to discharge a tube (kinda dangerous)
Toss it and get a new one.
Compaq 7550 monitor keeps turning pink. Works fine for a few minutes then back to pink and hard to see. Sometimes moving the mouse quickly will help but only for a few minutes. Have tried adjusting all...
Defective CCFL backlight may has the following symptom:
· Screen flashs on red/pink and off.
· Picture stays on in red and slowly be come normal.
· Picture flickering with dim display.
· Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
1helpful
DSC-T1 LCD looks like I'm looking thru night vision goggles!
Its problem of bad ccd imager in DSC-T1 and ccd imager will be replaced.
Sony announced free of cost repair scheme for ccd imager problem in DSC-T1 and you can see details on Sony CCD Support.
White colors come out pink and the wth bal is auto
I replied your question about pink tint noise in picture.
Akai PDP4294 - Snowy, pink & green picture
It is most likely a problem with the tuner, I would contact the place you purchased it or your nearest repair shop.
2answers
Its a fe-170
Have just encountered exactly the same problem with the same model! Looks kinda psychodelic!
k24674
ADMIN Andrew
ADMIN Andrew
