Question about Whirlpool Microwave Ovens
NTC Code on whirlpool microwave - Whirlpool Microwave Ovens
2 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: NTC cover message after replacing fuse
The "negative temperature coeffecient" (NTC) thermistor was left unplugged after reassembly or it is defective.
It is the hood thermistor, and should be plugged into connector P4 on the circuit board.
I think it should be at the bottom of the board, on a little tongue-like protrusion, as shown in the attached photo.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here (just enter your model number).
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Aug 17, 2009
Testimonial: "Thanks, using your photo as a reference, pushed NTC in firmly and have no other problems. Thanks again."
I have a fault code, NTC open call for service, on my whirlpool microwve WMH1163xvs. What to do?
Whirlpool Customer Phone Number Shortest Wait Best Support
Nov 20, 2014 | Whirlpool Microwave Ovens
Tip
Error Code F8E5
F8E5 Exhaust air template detection failure 1. Press CANCEL - CANCEL - START, verify failure code, and then press CLOCK/OPTIONS to display the exhaust air temperature sensor reading. Verify the sensor temperature reading is at room temperature (typically 50?F to 90? [10?C to 32?C]) and verify failure code. If failure code matches complaint, continue to Step 2. 2. Unplug microwave oven or disconnect power. 3. Disconnect sensor from ACU PCBA. 4. Measure HF NTC resistance between connector pins and confirm reading is between 9.5k??and 10.5k??at room temperature. If measurement is not correct, or if a short or open circuit is found, replace sensor. 5. Replace all parts and panels before operating. 6. Plug in microwave oven or reconnect power. 7. If the sensor temperature reading is still not correct, replace ACU PCBA. 8. If failure does not appear, stop.
on Jul 21, 2015 | Whirlpool WMH31017AW
Whirlpool mircowave model MH3184XP the display reads F2
There is a problem with the control pad. The membrane, or surface, of the pad may be broken or damaged somewhere, resulting in the F2 error code. This is common for Whirlpool microwaves.
Press "Stop/Cancel" twice and select a new cook program. Press "Start" to begin.
If the error code persists, press "Stop/Cancel" again and unplug the microwave. Wait several minutes and plug it in. If the F2 code appears again, it requires repair.
Replacement membranes can be found online
http://www.appliancepartspros.com/whirlpool-panel-asy-control-8205376-ap3775860.html
but the internals of a microwave are dangerous, having high voltages even when unplugged. With the cost of parts and labour from a service tech, you may be best buying a new oven.
Sep 04, 2013 | Whirlpool MH3184XP Microwave Oven
NTC OPEN CALL FOR SERVICE
The magnetron thermal protector is open. It is probably defective.
Aug 14, 2013 | Whirlpool WMH1163XVS Microwave Oven
Microwave says NCT is open
That would probably be "NTC", which stands for "negative temperature coefficient", which is just a fancy name for a thermistor.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
There should be a technical sheet hidden behind the grille or controller. It will show you where components are located and how to test them.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
Oct 03, 2011 | Whirlpool WMH1163XVS Microwave Oven
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
F7 ERROR CODE ON GH6177XPS
This is a known problem with this unit, and whirlpool has put out a Service Flash out on this. The reason this is happening is Electrical circuit interruption between the L1 and Neutral in the microwave invert circuit. This has to be addressed by a Tech.
DrakeTech
Dec 24, 2009 | Whirlpool GH6177XPS Microwave Oven
NTC cover message after replacing fuse in my whirlpool microwave MH1170xsb
Aug 16, 2009 | Whirlpool MH1170XS Microwave Oven
I keep getting a beep then (NTC open call for service) in the window. What is NTC and what would cause this message? My microwave hood combination Model#MH2175xst-o is working fine except for the...
It's a "thermistor", a type of temperature sensor.
NTC stands for negative temperature coefficient. When the temperature goes up, its resistance goes down, telling the controller the temperature.
Yours has failed and needs to be replaced.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 04, 2008 | Whirlpool Microwave Ovens
Microwave Ovens Logo
796 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
