Question about Maytag PYE2300AY Electric Dryer
Hi, my Maytag Perfoma PYE/G200 doesn't dry the clothes in one cycle. It usually takes 2 cycles to get damp dry. Also, the dryer sometimes won't start unless it has been sitting for 10 or 15 minutes and makes a loud noise when trying to push control in.
  • Maytag Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Nov 11, 2010
Timer goes to 99 minutes and clothes note drying all the way
Hi cayjr1
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Oct 09, 2012 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Legacy Electric Dryer Model MED5570tq0. It turns, gets heat, but does not dry the clothes. It would take 2-3 cycles to dry clothes. Any suggestions?
Hi jamesholl456...
Sounds like you have a Clogged Vent
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Cycling thermostat
This is a Free answer, Please rate me.
Apr 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
The sensor doesn't seem to work?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 22, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
My GE dryer takes 3-4 times as long as I expect it to to dry my clothes. I've read that it should take about 45 minutes to dry a load but after the first cycle the clothes are still damp. It usually takes...
You have checked a lot already ... thanks for the comlete story. Often the questions here hurt for detail.
Are your clothes getting hot?
Two reasons for not getting dry ...
No heat
No air.
You need warm air (heat and air) going through your drier to achieve dryness.
Sounds like you have no heat. Are you properly setup on the control panel (you selected heat)? You have physically inspected the entire exhaust sustem including the outside vent, hose and lint trap - absolutely clear ...
check the heat my friend
Oct 20, 2009 | Dryers
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag performa dryer pye/g2200
hi .thanks for the question .no the element does not go bad a little at a time. but the venting gets clogged up a little at a time . remove the venting and clean to the outside wall . also if the dryer is noisy you could have a blower problem. if the dryer is noisy .but check the venting thanks the appliance doc
Oct 01, 2008 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
