Question about Canon PIXMA MP780 All-In-One InkJet Printer
Canon Pixma MP780 makes a loud clicking noise. No paper jammed anywhere. It seems to be the gears where the cartridges are.
I have th same exact problem, just took much of it apart, bu still cant see why it makes the loud noise, also I cant switch paper feed to back, which at least would allow it to print from there... please let me know if you find a solution.
Posted on Nov 11, 2010
The paper feeder wont do it's job,will not feed paper . Makes loud noise but no action, then screen asks to load paper.
The feeder on this model has 1 weak mounting place for the gears that drive the feed roller. The plastic stud that holds the gear will break off of the frame and cause the noises you hear and no paper feed. The only fix is to replace the sheet feeder assembly, about $30.00 for the part.
Feb 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon error 5100 cartrige jumped
I think you are seeing "ERROR 5100: Cartridge Jammed", right?. Here is the most likely solution to this issue with your printer. The following procedure comes directly form Canon
ERROR LCD: CARTRIDGE JAMMED
1. Press ON/OFF switch to reset the multifunction device 2. Removing obstructions, foreign objects and paper jams MP750 / MP780 3. Reseat MP750 / MP780 print head 4. The MP780 may require repair
Feb 08, 2010 | Canon PIXMA MP780 All-In-One InkJet...
My PIXMA MP780 is still flashing check the printer then press ok - an error msge ##357 keeps coming up. what does this mean pls?
This is an error in the position of the paper feed unit.
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.Look in the sheet feeder too. If this not help your printer need service.
Oct 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cartridge is jammed
I have a canon pixma 780. It was working fine then I had a paper jam and message "Cartridge jammed" I removed paper with no difficulty-piece was not torn.Now it will not print at all Paper feeds through but no printing in any colour
Mar 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
MP780 paper jam
You need to open up the unit as if repalcing a cartridge and get a torch and really look hard for the jam it can be really tiny. Look in and under cartridge roller (paper roller too) and is the cartridge aligning itself when you open the unit so thta acartridge can be changed? Good luck.
Nov 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma mp780: jammed cartridge display but no apparent paper or other jam
turn on, lift cover, open front, and gently slide cartridge left and right sereral time, not touching the thin film or silver guide bars.
Aug 05, 2008 | Canon PIXMA MP620 All-In-One InkJet...
Paper jam
Smashed up against right or left inside frame wall, where print head slides left and right.
Nov 21, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
784 people viewed this question
old marine
old marine
