Question about Zanussi TC7102W Electric Dryer
TUMBLE DRYER WORKING BUT ONLY WITH COLD AIR - Zanussi TC7102W Electric Dryer
  • Zanussi Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
jsrock516
  • 5911 Answers
SOURCE: WHIRLPOOL AWZ2303 TUMBLE DRYER ONLY BLOWS COLD
It's call a bad thermal cut-out. You should have a thermal cut-out and a high limit thermostat located adjacent to the heating element (usually mounted right on the heating element housing). They both should read a short or fairly low resistance in the case of the thermostat. If the thermal cut-out is blown it is not a resettable device and must be replaced. The tco is usually sold along with the high limit thermostat. It is HIGHLY recommended that you replace BOTH at the same time. DO NOT attempt to bypass any of these devices either. They are there as safety devices to prevent overheating. You could end up with a fire if you do. Now...with all that said, the tco will blow for a reason. Not cleaning the lint trap will contribute to it, but the big item is the ducting. If the vent ducting is clogged you will experience longer dry times and eventually the tco will trip again. Take the time to THOROUGHLY clean and/or replace your vent ducting from the wall all the way to the vent opening outside. In addition, while you have the dryer open THOROUGHLY clean the inside as well. This includes the air baffle where the blower fan is located. Rule of thumb: if you have lint INSIDE the dryer, it's clogged somewhere. Good luck and I hope this helps you.
Posted on Sep 22, 2007
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
SOURCE: bosch exxcel tumble dryer blowing
Remove smallish cover in center of back, 2 self tappers. Press RED reset button till it clicks, located just left of center at the back.
Posted on Oct 16, 2008
  • 98 Answers
SOURCE: the tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Posted on Jun 07, 2009
  • 17 Answers
SOURCE: hoover tumble dryer filter light staying on and
if you have cleaned your filter at the door and checked the outlet is not blocked either then it will most likely be the heater element on the back of the machine, it has three parts to it, 1 thermal switch,2 is some sort of magnetic type switch and 3rd is the element its self,
problem is its only sold as one unit, but very easy to replace.
Posted on Mar 03, 2010
How do i fix a tumble dryer blowing cold air
When you have to put this question here, I don't think it is wise to try to repair it yourself. It can be caused by lots of different things, Like a defective heater, a lose connection or a defect thermostat. When your dryer does not have an overheating security switch that came out and you can't reset it, a skilled technician should see into the dryer. It works with voltages, to dangerous to work with, when you don't know what you are doing. Please be careful.
Jan 30, 2015 | Indesit Ariston Creda Hotpoint Tumble...
Simpson Dryer only blows cold air
It's either the fuse, heating element, thermal cut-off or thermostat
May 20, 2012 | Washing Machines
My Bosch Exxcel tumble dryer will only blow cold air
the heater element is toasted,but it's not hard to change and not $$$
Mar 28, 2010 | Dryers
Cold air
It seems that it is more likely a Burned Out Heating Element.
Check and let me know if the problem still persists.
Hope i helped you.
Thanks for using " Fixya " and have a nice day!!
Jul 11, 2009 | Zanussi TD4112W Electric Dryer
The tumble dryer is work but is only blowing cold air
Jun 07, 2009 | Zanussi TC7102W Electric Dryer
An indesit tumble dryer, only blowing cold air.
Most likely heating element or thermal cut-off is bad, or both.
Sep 14, 2017 | Dryers
My tumble drier dont heat up. It works but its
there will be a red overheat switch on the rear on most models, simply pull the machine out and press reset, the most cpmmon cause is running when empty or a build up of lint. if the doesnt work then it will be an open circuit element.
Apr 13, 2009 | Dryers
No heat coming out the tumble dryer
Electra is brand name for what was yeb so could have been made by several companys. Please check at back of drier for red reset button or rectangular plate at bottom right corner.
Dec 03, 2008 | Dryers
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Zanussi TC7102W Electric Dryer Logo
140 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
