Question about Microsoft Xbox 360 Console
I have one red light i conducted the check list provided and found the light comes on when the cable from xbox to the tv is plugged into the xbox. tried a new cable and it still occurred. this is not a hdmi cable that one works fine. also the other end is not plugged into the tv
  • 643 Answers
Its because its not plugged into the TV
Posted on Nov 09, 2010
How do i connect xbox to akura apl3268fd4 tv so its in hd
There are two ways to connect it.
1. The cable that came with your xbox should have two sets of plugs on it. One being the red, white, yellow and the other red, green, blue. You need to plug the red, green, and blue plugs into the tv with the same color plugs. You will also have to plug in the red and white for sound. The yellow plug is not needed. There will also be a switch at the base of the cable near the xbox. That needs to be set to HDTV. If your cable does not have the red, green, blue you will need to buy a cable that does have them.
2. You can use an HDMI cable. With that all you need to do is plug one end of the HDMI cable into the xbox and the other into the tv. Not all xbox's have the HDMI output though. If its new i should have it on the back of the xbox near the normal tv output slot.
If you use the red, green, blue you will have to set your tv on the component channel. If you use HDMI the tv will have to be on the HDMI channel
This will give you a more thorough explanation. http://support.xbox.com/en-us/pages/xbox-360/get-started/console/audio-video.aspx
If you found this helpful please give me a good rating. Thanks hope this helps
Nov 21, 2010 | Video Game Consoles & Games
Light is on and green but no video coming out to television what might be the problem.
Typically, this problem occurs if the audio/video (A/V) cable is not connected correctly, or if the A/V cable is faulty.
Solution 1: Set the television or monitor to the correct input
Make sure that the TV or monitor is set to the correct input for the console. Check the TV or monitor's manual to see how to configure the video inputs, or try to use the console on a different TV or monitor.
Solution 2: Connect the A/V cable securely
Sometimes, you can insert the A/V cable far enough to prevent any red lights from flashing on the Xbox 360 console but not far enough for the console to transmit images or sounds to the screen.
Solution 3: Switch the Xbox 360 Component HD AV Cable to the correct setting
Make sure that the TV/HDTV switch on the cable is set correctly.
  • For standard-definition TVs with only the yellow connector plugged in, set the switch to TV.
  • For high-definition TV or monitors with the red, blue, and green connectors plugged in, set the switch to HDTV.
For more solutions, check this web page.
Oct 09, 2010 | Microsoft Xbox 360 Console
Xbox switches on ok but no sound or vision output to tv?
If there are no red flashing lights around the power button, check your cables. The xbox doesn't like to be turned on without the A/V cable plugged in, so it might have come loose from the TV. I'd check the connecting point to the TV, and the TV settings (make sure it is set to the xbox input, and not, say, a DVD/cable box input)
The GPU (graphics chip) has been known to go bad quite easily on the xbox, but I wouldn't want to tackle repairing that unless you see the red lights blinking (which is a sure indicator that it needs to be repaired)
Nov 11, 2009 | Microsoft Xbox 360 Console
Four red flashing lights after downloading the update
four flashing lights means that there is an error with the a/v output check the plug that goes into your xbox and goes to the tv also check the switch is on one of the position on the cable (its the box which fits into your xbox and the cables run into the tv).
If your still getting 4 rings try a friends tv cable or a family members to see if your cable is faulty
Oct 25, 2009 | Microsoft Xbox 360 Console
XBOX not connecting to LG flatscreen -no visuals only sound
There is a switch on the cable where it plugs into the XBOX that says HDTV/TV please make sure that it is set to HDTV when using component connectors.
May 13, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
When connecting XBOX live to LG flatscreen there is no video only
There should be a switch on the cable that says HDTV/TV if you are using component connections, make sure that the switch is set to HDTV.
May 12, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Red Lights
Hello misspay,
According to Microsoft Support, the 4 red lights mean the Audio-Visual (AV) cable is not connected or plugged into your Xbox 360 correctly. Please make sure the AV cable is connected correctly to your Xbox 360. To do this, disconnect the AV cable and firmly connect the AV cable to the Xbox 360 console.
I hope this fixes your problem here is a link that will provide you with more solutions to try and fix the issue.
Sincerely,
Agent Xiong
May 22, 2008 | Microsoft Xbox 360 Console
Xbox 360-Red to Green
Look on the back of your tv and make sure that the red and blue cables are plugged into the right slot on the back of your tv. This would be the most common cause for something like this that you are describing.
Feb 09, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
