Question about Nortel T7316E 2-Line Corded Phone
I need help programming hunt groups. 1.)Ring 2 extensions if no answer then 2.)Ring next 2 extensions if no answer then 3.) Go to voicemail box I assign. I have created two hunt groups with the two pairs of extensions I am using, and cannot figure out how to attach that group to a specific extension.
    President:
  • Nortel Master
  • 860 Answers
Looks like you need to set your overflows from HG1 to HG2 then to extension xxx.I'd set the delay from 12 to 15 seconds.
Posted on Nov 09, 2010
  • 4 more comments
  • bdorris Nov 09, 2010
    Since we use CCR do we need to do something to make HG1 active?
  • george  peters
    george peters Nov 09, 2010
    You could make the HG a path in the CCR or change the greeting to add " for _____ press 625" or something like that.
    For some reason the previous programming (which I assumed was a hunt group) causes 5 of our phones to ring simultaneously, and I can't figure out how to remove that one. In the list of hunt groups there are only two (628 and 629 on HG01 and HG02), which I set up. If I dial my 628 hunt group from the CCR it still rings all 5 phones simultaneously.
  • george  peters
    Did you delete the 5 members from the group? Also check for answer DN keys on those sets to see if there set up on the same answer DN.
  • bdorris Nov 10, 2010
    Thank you! The former setup was using Answer DNs instead of Hunt Groups. I also didn't realize the **config had 2 passwords: admin and config. The options I needed were only visible when I used the config password.
  • george  peters
    george peters Nov 10, 2010
    Glad I could help.
One station is not ringing on night ring 1 setting
Night 1 will direct the calls to a predetermined hunt group. The extension not ringing is most likely missing from the hunt group. To correct this will require a programming change. This change needs to be made by your administrator or phone vendor that takes care of your phone system.
Sep 07, 2012 | Mitel Superset 4150 Phone
I have programmed a samsung dcs816 with ddi's allocating each one to a seperate group with a single extension in each but when the ddi's are rung ALL the phones ring no matter which setting i have the...
You should set the ddis on dcs816 to ring at the extention and not a group with only 1 member, this is much less complicated because groups can hunt for other groups if not answered. I have uploaded a video (of which there are lots on Youtube search abbeytel) which will help with this and other possible issues on the dcs816, or visit www.abbeytelecom.com , hope that you find this helpful.
Dec 13, 2010 | Samsung Phone PDCSLCD12B
Incoming calls goes to voicemail, then to receptionist. Also rings at three extensions at the same time.
It sounds like all the incoming calls are going to a hunt group. This would explain why three extensions ring, then it goes to the receptionist, and then ends up in voicemail.
Try looking for a hunt group that distributes to the three extensions in question, or that only has those 3 extensions active.
Dec 10, 2010 | Avaya 4610SW IP Phone
I set up Hunt Group 1 (290) on a CICS, w/6.1 softewre with A Call Pilot 100 and assigned & initialized mailboxes for each Hunt Group member (222, 223 & 224) to FNA to Voicemail (227) after 4 rings....
Without having the programming manual on hand for this switch I have to generalize from other switches. Double check your auto forward settings within your hunt groups. It sounds like you have auto forward set wrong. If you have the voice mail set to engage on the 4th ring try changing that to engage on the 6th ring with the forward within a hunt group to forward to next available on the 3rd ring, see if that helps.
Aug 05, 2010 | NorStar Cics 6.1 & Call Pilot 100...
Program "Do not disturb" on business phone
From the manual: You need to program a button with FEATURE 01.
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
¦ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
¦ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
¦ To avoid missing calls when Do Not Disturb is not needed, turn it off
Carl
Mar 16, 2010 | Lands Phones
I have three questions regarding the Avaya One-X Quick Connect G11 PSTN Gateway. 1. Can it be programmed to ring all phones and if noone answers then go to extension 200 voicemail? 2. Can you get rid of...
1. Can it be programmed to ring2.gif all phones and if noone answers then go to extension 200 voicemail?
Yes, you need to browse to the gateways IP and look at the destination of the lines. If a single extension is the destination, you need to make a group, put all the phones in it, and then point the lines to that group.
2. Can you get rid of the dial 9 to get an outside line and just grab available line when handset is picked up?
No, unfortunately you can not.
3.How do you eliminate noise and echo in the background when on a call?Also has some bleeding over, someone else in the office could hear meon the phone when they were on the phone.
Make sure the gateway is grounded to a good ground. if the problem persists, you can try to upgrade the gateway and phones.
Oct 09, 2009 | Avaya ONE-X QUICK OFFICE EDITION TRUNK...
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Apr 15, 2009 | NorStar Lands Phones
Need to turn off transfer callback on Norstar Meridian
Ok, well I can explain most of the programming template, but I cannot give you the exact buttons to push since each phone IS programmed differently.
-> first dial FEATURE 985 this will give you the DN(Extn) for the voicemail (record this number) and then RLS
-> now I need you to dial FEATURE 0 on your set, and press the Intercom key to ensure the extension of your set you want to change and then hit RLS.
To get into programming press FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will see 3 arrows on your LCD
<- Heading Enter->
<- Back Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change.
-> you should now see the extension of the set and the name that is associated with it, press Enter (the top right arrow key) again
-> now you will see LINE ACCESS and press Next (the bottom right arrow)
-> then you will see CAPABILITIES and press Enter. now you will see FWD NO ANSWER and press Enter, and put in the DN of the voicemail you saw with the Feature 985
-> hit Next for the number of rings you want to ring at the set before going to voicemail.
-> hit next and you can now RLS to back out of programming.
Voila, that set once called will now goto voicemail.
-OR-
You can get the receptionist to dial FEATURE 9 8 6 and the extension to transfer directly to someone's voicemail.
Apr 13, 2009 | NorStar Meridian M7310 Phone
Call pilot 100 hunt group
Not too sure if you really need that dial 0 point, since the calls are already ringing in on the receptionist desk.
You can create changes and make a hunt group, with an over flow with another hunt group, which will rings specific people, and if there is no answer the over flow can go to a voicemail or auto attendant... more programming than I would like to type.
Simple solution: Make sure that everyone that you want to answer the calls, they are in the same pick up group.
Then if the people that you want to answer hears the phone ringing, they just have to dial Feature 75, this is group pickup.
To find out if the people are in the same pick up group:
-> go into the system programming
-> TERMINALS&SETS and enter the extension
-> find CAPABILITIES and enter
-> hit next till you find Pickup grp: this will have a number and ensure that all the sets you want have this same number.
-> rls to back out of programming.
This way anyone that hears the phone ringing can answer anytime they want.
Mar 20, 2009 | NorStar Cics 6.1 & Call Pilot 100...
PICK UP GROUPS AND HUNT GROUPS
You will need to talk to the phone administrator. It needs to be set up in system admin.
Nov 08, 2007 | Avaya Definity 6408D Corded Phone
Nortel T7316E 2-Line Corded Phone Logo
802 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
