Question about Dell Dimension 8400 PC Desktop
My dimension 8400 has been mothballed for nearly 2 years,cant get it to boot up i have put in a new cmos battery ,i now get the black dell screen the bios is A05 it just does not load up Help needed
  • 1,179 Answers
I suggest going through my tip pertaining to this matter, it is entitled My Computer is not
turning on!!! Is it dead!!! No POST!!! this should guide you through the process and get
your PC going again.
Thanking you
damnor01
Posted on Nov 10, 2010
Dell 8400 Boots to Black Error Screen in XP States to reinstall System 32
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
If hard drive is ok after test, insert in your original Windows installation media and reinstall OS.
Oct 02, 2012 | Dell Dimension 8400 PC Desktop
More likely it is a HDD problem, allow it to reinstall system 32
When trying to boot PC all i get is black screen and message:- X300 SE 128MB BIOS P/N 113-A33406-100. Have replaced bios battery on motherboard an checked connections etc but still displays same message....
no problem friend please open your cpu shutter and you can see here a cell like watch's cell plug it out and replace it with the new one and start your computer now your this problem is 100% solve. thanks
Jul 14, 2011 | Dell Dimension 8400 PC Desktop
Dell 8400 No Boot, not even POST
It sounds like your bios were improperly flashed or went bad. The X300 SE message is your video card. So your video card works, the system mostly works, but the BIOS isn't starting up. You should contact Dell and tell them the situation.
Apr 19, 2010 | Dell Dimension 8400 PC Desktop
My dell dimension 2400 will not boot up. It goes to a black screen and displays either keyboard failure or F1 or F2 options
This can usually be solved by resetting the CMOS.
Unplug the power from the back of the tower. Open the side of your case and locate the round battery near the lower-right side of the main board. Pop the battery out. Just below it you should see 2 little gold colored pins sticking up. Right around it it should say 'Clear CMOS' in very fine print. Take a small screwdriver and hold it to the two pins so they are shorted or touching each other through the screwdriver for a few seconds. Place the battery back in the machine and see if this works.
Oct 22, 2009 | Dell Dimension 2400 PC Desktop
[Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Apr 27, 2009 | Dell Dimension 8400 PC Desktop
My dell dimension 8400 bios a03 fails to bootup and displays this alert on the screen: Many attempts to boot the system have failed at checkpoint [Ithr]. how can i recover from this?
You need to reset your bios settings. Open your case and remove the cmos battery for 10 minutes. Caution: unplug all ac plugs before you open your case. put the battery back in and turn it on you should see an error message saying: you need to set system time and date. If you see this then you have successfully reset your bios settings and the defaults should load up. follow the instructions to change your time and date settings and save. reboot and hopefully you can boot up. I hope this works.
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension power problem
There are several different solutions for this as posted at this Forum.
http://www.tomshardware.com/forum/51352-2-dell-dimension-8400-wont-boot
1) A lot of people have just removed the Jumper for the CMOS and turned the Power back on and back off and replaced the jumper and/or removed the battery.
2) Several people have reseated the Memory and after booting back up it worked.
3) A few had to replace the Mother Board and CPU but in this instance they had to also replace the Case because the Dell case wasn't really fit for the heat of from the CPU.
4) I had the exact same problem and luckily replacing the Power Supply fixed this for me. I had to cut out the back of the Dell case for the toggle on/off switch but when I tested the old Power Supply it was only getting 5amps and this was causing the Amber/Orange/Yellow light to constantly flash.
I hope this helps!
Jan 20, 2009 | Dell Dimension 8400 power supply ** FREE...
Error reinstalling Windows XP on Dell Dimension 8400
Sounds to me like the hard drive is bad.Download some testsoftware that does not require windows and test it.
http://www.seagate.com/www/en-us/support/downloads/
Jan 15, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 8400 PC Desktop Logo
166 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
