Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WD63 Hi Guys, We have a WD63 approx 3 years and it's seen little usage in that time.It's been lying idle for the last 1 as we had a second machine. We gave it to a friend and when we moved it and plugged it in there was no power light coming on. Intially I thought the plug/fuse so I replaced both but no luck. Any ideas what the next step should be as there isn't a buzz out of it. Btw: Before I moved it I never checked to see if it was working, so I'm not sure how long it's been like that. Any help would be very much appreciated. thx.
  • Larsirl Jun 27, 2008
    Cheers mate....It was as simple as that!
Sometimes the door lock doesnt engage properly! This could be the cause, give door a good slam shut. Hope this is of help.
Posted on Jun 26, 2008
I have an Electrolux High Speed Oven E30SO75FPS that's 3 years old and the Magnetron has failed for the 3rd time. What can be causing this?
Is the internal cooling fan working?
Are the ducts and vents clear?
Problems with any of those can result in overheating, which destroys magnetrons.
I have seen high voltage rectifier diodes interact with magnetron in funny ways. I'd replace the diode, too.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Finally, baking potatoes and making popcorn really give the magnetron a workout.
You should put about 1/2 cup of water in the rear corner of the microwave when cooking those foods.
It helps "preload" the oven to prevent execessive microwave energy reflection back to the magnetron.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Dec 12, 2011 | Microwave Ovens
Where do I find the filter on my Hotpoint Aquarius WM22? Or does it not have one?
Both the Hotpoint WD63 (wash dryer) and the Hotpoint WM22 (washing machine) have a drain filter in the sump hose at the bottom of the tank.
This filter is a last line protection for the pump and is not designed to be cleaned on regular intervals by the user.
Jan 31, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD63 not spinning correctly
Two things to check.
Remove rear cover.
Remove large black hose onto drum
Remove and clean filter inside hose.
Next--remove top cover and check the brushes in the motor, if they are less than 3 or 4 mm long, then replace them.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarious wd 440 two years old tripping main board
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
I cannot get the LCD view screen to work ?
There should be a menu button on the camera. if there is, go into the settings and turn the LCD Screen back on. (Actually if you press the menu button on the camera, you should see the menu on the LCD screen.) There is an option to turn off the screen to save battery life.
Dec 17, 2008 | Nikon D70s Digital Camera
No power??
It's more than likely its the door lock, if not check the timer contacts on the top front connection block, if they have blown it will need a timer & door lock
Nov 02, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
LCD Screen problem
You have a failed inverter circuit. This is a very common fault with BenQ and other LCD monitors. I have seen more FP737 and FP731's and all their cousins in the last 2 years then I care to count.
You will be best to take it to a TV technician and have them do the repair. There are ways to fix it yourself, but the chances of success are not great without a decent amount of electronic knowledge.
Call several places and get approx quotes based on the inverter fault. A lot of TV techs will not work on LCD monitors and is another good reason to call around first.
One final thing, check the manufacture date on the back of the monitor, these normally come with a 3 year warranty and it will be either expired now, or very close to it. If it is still under warranty, then contact BenQ near you to facilitate the repairs.
BenQ support webpage.
Apr 15, 2008 | BenQ FP731 17" LCD Monitor
Hotpoint TDC62 condenser dryer does not heat up My hotpoint tdc62 does not heat up. I had it for approx. 5 yrs, have changed the thermostats(years) before,but have come up with a new (recent)problem. when...
I think the problem still lies with the thermal switches, they have a tendancy to corrode where the spade connector attaches to the body (see pic)
Mar 11, 2008 | Dryers
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
77 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
